08 diff cover
Old Sep 29, 2010 | 07:23 PM
john8403's Avatar
john8403
08 diff cover
just got mt 08 diff. cover what size bolts will it take the factory ones in my 01 wont be long enough right. Also purchased 8 oz. of friction modifier to go in gear oil was thinking about using royal purple 75/140 is it worth the money or should i go with another synthetic. thanks
Old Sep 29, 2010 | 07:52 PM
big poppa's Avatar
big poppa
5/16-18 X 1 1/4 bolt size, thanks to partsguyed.. I got my RP 75-140 synthetic for 9.99 a quart at Pep-Boys, must have been a sale or a mistake but grabbed it fast, good stuff, its been in mine for about 50,000 miles. It has the modifier already added to it but you might have to add a bit more modifier to it, I did, still had grabbing around tight corners. I added about a half bottle of the 5 oz Motorcraft bottle.
Old Sep 29, 2010 | 08:19 PM
john8403's Avatar
john8403
i bought two bottles of the ford modifier so should probably use both bottles with the royal purple hope i can find it at that price goin to try pepboys tomarrow
Old Sep 29, 2010 | 08:21 PM
7.3 Rocket's Avatar
7.3 Rocket
If you can't get bolts locally you can order a bolt kit through Clay.
Riffraff Diesel: 08' Diff Cover Bolt Kit
Old Sep 29, 2010 | 08:22 PM
Ponyboychris's Avatar
Ponyboychris
I have a non-LS diff and the Valvoline 75w-140 Sythn oil didn't need any additive. It had some in the oil already but again, I have a non-LS diff.
Old Sep 29, 2010 | 08:56 PM
john8403's Avatar
john8403
im assuming mine is LS rear
Old Sep 29, 2010 | 09:16 PM
Izzy351's Avatar
Izzy351
DO NOT add any FM unless it chatters , then add 2oz at a time until it quits. If you add too much, you end up with an open diff, essentially.
Old Sep 29, 2010 | 09:22 PM
john8403's Avatar
john8403
what about the amsoil gear lube anyone using amsoil products
Old Sep 29, 2010 | 09:26 PM
john8403's Avatar
john8403
ford parts guy told me to put both bottles in rear to start with i was worried about too muchslippage thats why i came here first thanks izzy351
Old Sep 29, 2010 | 09:31 PM
Izzy351's Avatar
Izzy351
No problem... Royal Purple has the FM in it already, as do many of the 75W-140s out there. I run RP in mine with the '08 cover and like it fine. Obviously, if you have an open diff, it doesn't matter either way. Check your door tag for the code under "axle". "31" = non LS, "C1" = LS (assuming 3.73 diff).
Old Sep 29, 2010 | 09:38 PM
john8403's Avatar
john8403
open meaning non LS {sorry}
Old Sep 29, 2010 | 09:39 PM
Bonanza35's Avatar
Bonanza35
My neighor uses amsoil because when towing his diff oil temp wouldn't go down after climbing a hill. With the amsoil it returned to normal very quickly. He has a 38 foot toy hauler and gauges on everything.
john8403's Avatar
john8403
and that cover looks great gonna do mine tomarrow
Old Sep 29, 2010 | 09:41 PM
john8403's Avatar
john8403
i had several people tell me to use amsoil but i cant find in retail only mail order to my area in va.
Old Sep 29, 2010 | 09:46 PM
Izzy351's Avatar
Izzy351
RP is okay stuff. Most will do you fine, as they're all syn in that weight from what I've seen anyway. Just make sure you verify whether it has the FM added already or not before you do anything, as well as check your door sticker code. If you have a non-LS diff, presence of additive or not makes no difference to you.
ssg510
Modular V10 (6.8l)
Dec 3, 2013 01:39 PM
95350PS
Aug 6, 2013 08:44 PM
bobalonius
Apr 6, 2012 05:19 AM
superstroker123
Mar 20, 2010 12:48 AM
Storm
Oct 9, 2007 08:24 AM
