Sponsored by: Real Truck
high pressure leak
Old Sep 29, 2010 | 09:59 AM
cardinal thunder's Avatar
cardinal thunder
high pressure leak
2005 F350 will not start when warm when cold will start but runs rough till warm took it to the dealership said I had a leak at a high pressure pump. way to much to money to pay to have them fix. Has anyone ever had any experience with this how hard is this type of repair.
Old Sep 29, 2010 | 10:01 AM
gearloose1's Avatar
gearloose1
What proof did the dealer have that it is HPOP?
Did he do the air leak test?
Old Sep 29, 2010 | 11:26 AM
cardinal thunder
leak
yes they said it was a leak from a fitting on the high pressure pump
Old Sep 29, 2010 | 11:40 AM
06silvercrew's Avatar
06silvercrew
You can change just the fitting, its like a $50 part. Normally refered to the STC fiting (snap to connect)
Old Sep 29, 2010 | 11:57 AM
gearloose1's Avatar
gearloose1
If you are going to do that, might as well do o rings, check a lot of other stuff inside there while you are at it... and also... clean the turbo if that hasn't been done.
Old Sep 29, 2010 | 12:01 PM
gearloose1's Avatar
gearloose1
Outline the diagnostics procedure that led to that conclusion.
rockenr
Sep 18, 2013 03:00 PM
Mkmw522
May 20, 2013 03:37 PM
holdtyte
Nov 12, 2012 10:43 PM
jordan101
Mar 14, 2011 08:21 AM
jkdank
Dec 27, 2009 12:13 PM
