Sponsored by: Real Truck
Elecrical
Old Sep 28, 2010 | 09:50 PM
Diesel Driver's Avatar
Diesel Driver
Elecrical
Own a 2002 SD 350, 7.3L and have an electrical snafu that even the dealers service department can not figure out. I put the key into the ignition turn it on wait for glow plug light to go out. Truck starts normal BUT....when i go to put windows up or down nothing happens, clock and radio does not work. Everything else is AOK. Wait a couple of seconds to a minute, the clock comes on, the windows and radio works. Local service department now has three of these and mine is #4. Any ideas????
Old Sep 28, 2010 | 09:51 PM
gearloose1's Avatar
gearloose1
Replace every relay in the junction box.
Reset the computers.
jc8825's Avatar
jc8825
Accessory delay relay.
Old Sep 28, 2010 | 09:55 PM
gearloose1's Avatar
gearloose1
The relays are dirt cheap.. might as well do them all at once.
Old Sep 28, 2010 | 09:59 PM
jc8825's Avatar
jc8825
I wouldn't say dirt cheap, but yes you could change them all at once fairly inexpensively, but I would go with just the one that controls the devices that are malfunctioning.
Old Sep 28, 2010 | 10:17 PM
gearloose1's Avatar
gearloose1
$9 a piece is what I just paid, there are about 5 or 6, for $45.
That is cheaper than a gasser oil change.
Apply the cockroach theory:
Cockroach theory is the idea that one item of bad news is an indication that there is more bad news to come: in the same way that seeing one cockroach is an indication that there are more lurking out of site.
That is why many critical parts (brakes, tires, etc.) are replaced in pairs.
Old Sep 28, 2010 | 10:22 PM
jc8825's Avatar
jc8825
Parts that wear evenly, yes. The relays do not necessarily wear evenly.
Old Sep 29, 2010 | 07:20 AM
gearloose1's Avatar
gearloose1
Yup, and it is technically possible to substitute worn relays from one circuit to another.
Old Sep 29, 2010 | 11:25 AM
Diesel Driver
Just talked to the Ford Service Manager and they said it was a "Battery Saver Relay in the instrument cluster." The fix was to replace the entire cluster at a cost of $700, OUCH!
Old Sep 29, 2010 | 12:03 PM
gearloose1's Avatar
gearloose1
For a tiny fraction of that price, the panel can be "rebuilt" by a qualified shop.
Old Sep 29, 2010 | 12:13 PM
Diesel Driver
Where can I find one of them?
Old Sep 29, 2010 | 12:16 PM
gearloose1's Avatar
gearloose1
Google your local area --- there is usually a shop nearby.
Be sure you tell them it is a relay that needs replacing --- and not just the usual LCD gone bad thing.
Old Sep 29, 2010 | 12:24 PM
Diesel Driver
Thank you so much. I really appreciate the help!!!!!
