1986 F250 HD Rough Shut Off
I am having a bit of a problem. Sometimes when i shut off my truck, it sputters or fires a couple of times before completely stopping. One time it actually almost started itself back up. I think it may have something to do with the clutch. Usually pumping the clutch a couple of times before turning it off does the trick. Any help or ideas would be greatly appreciated.
Is this auto or stick truck? If auto is that 600-700 in gear or out?
What heat range are your spark plugs? If too hot they can become "glow plugs" and could be the cause.
Also a lot of carbon build up on top of the pistons as it stays hot to burn the fuel being pulled in.
That is why you don't get much run on with EFI as the fuel is cut off along with the spark.
Dave ----
Welcome to FTE.
Dave ----
Dave ----
its a borg warner t19 manual ,460 ci ,carborated(still has all the emissions junk on it which im getting rid of soon) and im in neutral when shut off. For the spark plugs they are the normal motocraft plugs nothing special. I havnt checked for carbon build up yet so ill have to look at that. Would timing be an issue ? I keep getting told the timing is fine because it passed emissions perfectly last time.
Timing advance vacuum hose was cracked and brittle. Its funny how that little fix has made it run a little better and stop the really bad dieseling i was getting still rough shut off though. Was going to replace the pcv grommet anyways but then hit a road block with the emissions tubing getting in the way. So thats great. But oh well its all coming off anyways. Btw i got a solid 9mpg today guys 😂 feelin pretty happy bout that😆
I dont have an issue with detonation. Starts up everytime with 1 crank ever since i replaced the cracked timing advance vacuum line it hasnt dieseled since. Its weird that it fixed it lol
