(btw - the issues w/ the FICM most likely aren't a Ford design issue, but instead a quality control issue. I believe that the location of it was to protect it from vibration, heat, and moisture - well as much as possible and not require the cost of an extra long cable.)
The E series mount the FICM on the body --- and with that change, correspondingly far lower failure rates.
This is despite a large number of diesels operated in extreme conditions as ambulances --- mind you the E 6.0 is derated.
IMHO, if I had an F,
I would, without lengthening the cable, try to at the very least,
remove the box from the engine and mount it to the body
Add in a system of heat shields (to reflect radiant heat from engine) and insulation to limit heat from the exhaust conducting into the box.
Then, I would add an insulated duct to bring in cold air.
If I were towing and operating in desert like climates, I would add a thermostatically controlled powered fan that measures temperature at the box to draw in cold air.
I would not let the box get within 40ish% of the melting point of the solder on there.
That is 220C - 430F.
I would set the limit at 150C or 300F
Actual calculations will need a EE that does thermal envelope calculations and ideally, have a simulator that can model the components in that box.
Hopefully I have the same amount of luck. I know I have a issue with the FICM (Voltage test 4 times) so I'm going to fix that first. Next Im worried about the IPR maybe causing the couple surges I have had in the past. (Fingers crossed)
Another question, has anyone done buisness with Ford 6.0 FICM | Circuit Board Medics
They are a little lower price on there repair then Swamp.
Still not 100% on doing this myself, if I happen to damage something trying to fix it myself I could loss a core charge.
Thanks everyone!!
