New Guy needs help
Old Jan 1, 2014 | 07:15 PM
bigj0094's Avatar
bigj0094
Exclamation New Guy needs help
Hope I am doing this right.........2004 F-350 ..The exhaust gas so rich, it burns you eyes.....No exhaust leak, its all coming from the end pipe..... 4" cat back
Now a little history......bought the truck in 2011 and 2 weeks after I bought it I had oil leaking from some ICP ? seal on the top of the motor.. Dealer fixed for 300.00 (Rip OFF) then HP oil pump went out.. Found a good guy in Dallas who pulled the cab off the frame and took the engine apart and replaced all failed ford _*&*&^ parts. EGR delete, ARP studs , Evolution programer, 2 fuel injectors, stripped and cleaned the turbo and 4" cat back exhaust. Ran great for 6 months and started going thru injectors. #1 in New York, 2 & 5 in Missouri, made it to PHX AZ and now my Programmer was saying only 36 volts at the ficm.. So I installed the famous Bullet Proof Diesel FICM and my programmer is now saying I have 48.5 volts but the # 2, 4 , 7 injector contribution balance issues.... My questions are 1. did the low voltage damage the other injectors . 2. could this be the reason for the rich fumes. I never had a problem with the fumes, Truck has no smoke at all, starts fine, no cold starts, I did update the Programmer from the Evolution web site , but they told me that it did not change the running program....so it could not be their fault. The guys in Dallas explained that they installed a stage 2 FICM ???? and to make sure not to ever have it flashed by a dealer .....the Bullet Proof FICM I only changed the VOltage side so the ficm program did not change ...Don't know where to start .......Have not found any one in AZ I trust.:- any help would be appreciated
Old Jan 1, 2014 | 07:30 PM
goosehunta's Avatar
goosehunta
you could just have injector stiction. and the injectors may be saveable.
im not sure about your rich condition though.
what oil are you running? what oil filter are you using?
we have some great folks here that will give great advice. they should start dropping in soon.
Old Jan 1, 2014 | 07:38 PM
bigj0094's Avatar
bigj0094
I am online and would love to talk to anyone with advise.........I will wait
Old Jan 1, 2014 | 07:42 PM
bigj0094's Avatar
bigj0094
I don't know if I am buying bad injectors from Oreily auto parts, or should I replace all of them at one time....... I am tired of doing them 1 or 2 at a time.... I am going to have to take it to some one for diag. Whats weird is it will run fine when I first start it and after about 20 miles or so then the code show up on my programmer and it starts running like crap.......but the fumes are there all the time even when its running good. I reset the codes on my Programmer and the next day same thing happens after 20 miles or so
Old Jan 1, 2014 | 07:43 PM
bigj0094's Avatar
bigj0094
I would like to buy a diag program that works with my laptop ......Any Ideas
Old Jan 1, 2014 | 07:50 PM
goosehunta's Avatar
goosehunta
if you want one that works with a laptop then I would say AutoEnginuity.
I just purchased it a few week ago and I like it. although you will need the ford enhanced version. about $400 out the door. it does a lot of stuff.
or you could go all out and get the Ford IDS for a couple grand.
Old Jan 1, 2014 | 07:53 PM
goosehunta's Avatar
goosehunta
lets get some information about your truck posted.
what year?
how many miles?
what kind of oil do you run?
what oil filter do you use?
what all has been done sence you have had the truck.
you said your getting your injectors from oreillys, which ones are they. most around here would say motorcraft new or motorcraft refurbished only.
Old Jan 1, 2014 | 08:00 PM
9228.bobcat's Avatar
9228.bobcat
Have you tried to run it without the programmer?
Old Jan 1, 2014 | 08:02 PM
lupuseven's Avatar
lupuseven
Bad FICM is reported to damage injectors for sure
also check harness' for wire chafing
You can check the injector solenoids:
Originally Posted by BLADE35
THERE ARE 2 COILS IN EACH INJECTOR
1. OPEN COIL WHAT HAS + AND - WIRES
2. CLOSE COIL WHAT HAS + AND - WIRES
OHM EACH COIL (+ AND -) IF GOOD SHOULD SEE 4 OHMS OR LESS
AND SHOULD BE OPEN TO EACH OTHER
Old Jan 1, 2014 | 08:09 PM
bigj0094's Avatar
bigj0094
I am just using the oil and filters from Oreilys ... I want to change to synthetic.
Old Jan 1, 2014 | 08:17 PM
bigj0094's Avatar
bigj0094
2004 F 350 w/ 6.0 Oil is rotella 15-40 , with a Fram filter, Just changed all fuel filters, and installed new Ficm. , NEW is high presure oil pump, EGR delete, ARP head studs, Oil Cooler in the block all bullet proof diesel parts, fuel injectors 1,2, 5 and 2 more not sure which ones all from oreily auto. not sure the brand, oh and the oil presure sensor on the top of the motor blew out and was replaced last month.
Old Jan 1, 2014 | 08:18 PM
bigj0094's Avatar
bigj0094
No wire chaffing found, and I have not tried to run without the programmer , I guess I could uninstall it and try that
Old Jan 1, 2014 | 08:30 PM
bigj0094's Avatar
bigj0094
]No wire chaffing found, and I have not tried to run without the programmer , I guess I could uninstall it and try that.....
This whole Forum is to cool.......there are so many shops out there that don't know didly about the 6.0....and way to many issues with this engine...thanks for all the help ........I have way to much money in this truck to give up.......
Old Jan 1, 2014 | 08:34 PM
bigj0094's Avatar
bigj0094
oh yeah forgot I just replaced the radiator and flushed the system, and installed new overflow tank and cap............then I installed 2 new battery's , ( thought might help the ficm voltage thing ...........(Was not related ) I did not know the ficm was bad until I downloaded the newest version from Evolution on the programmer , it now shows the ficm voltage on the gauges
Old Jan 1, 2014 | 08:57 PM
goosehunta's Avatar
goosehunta
what fuel filters did you install?
