1978 - 1996 Big Bronco
1981 bronco with 79 400 engine issues
Old Sep 26, 2010 | 04:39 PM
blackbettybronco's Avatar
blackbettybronco
I have a 1981 bronco with a 1979 351m/400 in it. I bought a cam for the 351m and installed it and i went to put the distributor in, and it sits all the way down in the block, but does not catch on the teeth. why? any suggestions? also, do i need to buy cam for a 400? and what distributor do i need to get, the 351m distributor, or 400 distributor? i know theres a difference, btu i dont know what exactly. any help is apreciated thanks
Old Oct 1, 2010 | 04:13 AM
StuntmanFyke's Avatar
StuntmanFyke
351M, 400, 429, and 460 all use the same dist along with bellhousing pattern and flywheel/flexplate. And the only difference between the 351M and 400 is stroke.
Old Oct 5, 2010 | 07:52 PM
Cudaguy's Avatar
Cudaguy
Compare the new and old cams side by side. Maybe you got a 351 W?
memoryman
17
Feb 28, 2013 08:19 PM
blackbettybronco
Oct 2, 2010 09:55 PM
70converter
22
Jan 4, 2010 07:24 PM
ClatonK
Oct 16, 2005 06:47 PM
F100_1964
Jan 8, 2004 07:35 PM
