Steering problem. Need advice please!
Old Sep 26, 2010 | 03:46 PM
zottyzot's Avatar
zottyzot
Ok, here's the deal:
1996 F-250 4x4 351 automatic, regular cab.
I'm having some serious steering problems. The wheels don't return to center after a turn, so I have to turn the wheel to get back to center. I dont see anything obviously wrong. I jacked up the front end and I can't turn the wheels left or right by hand, I'm pretty sure I should be able to though. I tried to remove the pitman arm from the steering box to see if anything in the steering linkage is binding but I couldn't get it off...
The power steering pump seems to work fine, i.e. it turns left and right ok, just wont return to center.
Any help would be great, I dont want to just throw parts at it.
Thanks,
Mike
Old Sep 26, 2010 | 05:54 PM
deeznuts822's Avatar
deeznuts822
Axle u joints, Usually when the joints dry up they cause the problem you describe
Old Sep 26, 2010 | 05:57 PM
zottyzot's Avatar
zottyzot
I greased the rod ends and ball joints...I forgot about the u-joints.
I'll check that out tomorrow! Thanks.
Old Sep 26, 2010 | 05:58 PM
wycowboy63's Avatar
wycowboy63
Thanks,
Mike
X2 on the axle ujoints, check them.
When you jacked it up and couldn't turn the wheels did you think to unlock the steering wheel? If you left it locked, thats why you couldn't turn them. Sorry if this question upsets you but I had a friend call me one day with this problem and thats what he forgot to do.
Chris
Old Sep 26, 2010 | 06:05 PM
zottyzot's Avatar
zottyzot
Not at all, I actually did forget at first, but realized it quickly.
Old Sep 26, 2010 | 06:08 PM
zottyzot's Avatar
zottyzot
Do you guys think hitting them w/ the grease will help at this point??
Or are they shot?
The truck(steering) was fine when I parked it and it sat most of the summer w/out moving. I put a new exhaust mani on recently and noticed the problem.
Old Sep 27, 2010 | 07:41 AM
fordyduty's Avatar
fordyduty
if dry u-joints are the cause of the problem then it's too late and the damage is done. Greasing them is only a bandage. It could last years to come or days it really depends on how much their used.
Old Sep 27, 2010 | 07:51 AM
zottyzot's Avatar
zottyzot
Thanks Fordy,
I'm interested to see if greasing solves the problem, even temporarily. At least then I know what I'm dealing with...
Old Sep 27, 2010 | 03:29 PM
zottyzot's Avatar
zottyzot
Took a quick look at the U-joints just now...They're shot. One side is missing the needle bearings, the other side is really bound up. Looks like I have another project to work on...
Thanks for the advice guys!
shadylemon1
Apr 18, 2019 02:29 PM
insurr3ction
Dec 1, 2018 12:53 PM
v10Excursion04
Mar 16, 2014 12:36 PM
3004speed
Feb 22, 2009 08:34 AM
oldsledder62
Bronco II
Apr 21, 2006 12:09 AM
