Steering issues
Old Mar 9, 2014 | 05:40 PM
v10Excursion04's Avatar
v10Excursion04
Steering issues
04 v10 excursion with steering issues. Whenever I turn (Left or Right) the steering wheel will not return to center, I have to turn it back myself, its really easy to turn back, but i get no help at all. There doesn't seem to be very much play in the steering, and the power steering works pretty good. My guess is steering box, but i'm not sure?
Old Mar 9, 2014 | 05:48 PM
LivingLarge's Avatar
LivingLarge
More details, has it been doing this since you've owned the Ex? Did it start recently? Have you had any front end work?
Old Mar 9, 2014 | 06:02 PM
v10Excursion04
I bought it 4 months ago, and its had the issue since day 1. the only thing I've had done to it was an alignment.
Old Mar 9, 2014 | 06:09 PM
LivingLarge
My guess is the previous owner tightened the steering box to much, you may get lucky and be able to back it out a little. ( search here for steering box adjustment )... Some claim if you over tighten your box it turns to toast, but at this point you have nothing to lose by backing it out a bit.
2nd guess you may have something binding, like your front steering stabilizer ( but I'm leaning more to your steering box ).
Just my .02
Old Mar 9, 2014 | 06:26 PM
v10Excursion04
I've been wanting to try and adjust it, but i haven't had the time.
Old Mar 9, 2014 | 06:27 PM
LivingLarge
You may get lucky, just back it out a little at a time.
Old Mar 9, 2014 | 06:29 PM
Az_Ray's Avatar
Az_Ray
Have you tried greasing the front end? Including ball joints(if they've been replaced)
Old Mar 9, 2014 | 06:34 PM
jayjjcc's Avatar
jayjjcc
Have you checked your balljoints? I have the same issue. I've tried adjusting the steering box, replaced steering stabilizer and replaced center link and greased outer tie rods and balljoints. Nothing helped... I'm changing my balljoints soon as they're badly worn. Hopefully that'll help.
Old Mar 9, 2014 | 06:57 PM
v10Excursion04
I haven't checked them. Whenever you get them changed let me know if it solves the issue.
Old Mar 9, 2014 | 07:11 PM
v10Excursion04
I had everything greased when I got alignment done.
Old Mar 9, 2014 | 07:34 PM
jesse5's Avatar
jesse5
Many things can cause the problem. Remove tie rods and move knuckles be hand checking for free range of motion which will tell you if the ball joints are binding or the axle joints.
Old Mar 9, 2014 | 07:39 PM
EXv10's Avatar
EXv10
Might be the tires, remove the stabilizer, check everything for grease and rotate the tires. Jack it up and wiggle the wheels too.
Old Mar 10, 2014 | 01:48 AM
double ott ex's Avatar
double ott ex
I am in the binding ball joint camp. pop the tie rods off and see how easily you can turn the wheels.
DOE
Old Mar 16, 2014 | 12:36 PM
TIUSER's Avatar
TIUSER
DOE
That is what I am thinking too.
Fordsdad
Nov 21, 2013 06:52 AM
midsouth
Apr 6, 2012 07:01 PM
SIRed
Mar 2, 2010 03:23 PM
CanadianSmokie
Oct 25, 2007 11:28 AM
