I HAVE A 2005 EXCURSION. THE HEADLIGHTS JUST QUIT WORKING. THE DRIVING LIGHTS WORK. THE HIGH BEAMS WORK WHEN THE SIGNAL LEVER IS PULLED. IVE HEARD THAT IT COULD BE THE MULTI-FUNCTION SWITCH?
low light sensor is working properly and activates parking lights. i have had this trouble intermittently and would fix itself without any input from me. now they wont come on at all
Check fuse box in the engine hood.
Think the ones for headlights are 10A mini's. When you pop off top you'll see layout for fuses and your owner's manual will have the Slot/Fuse needed in it.
I had that issue with one headlight, swapped out, and blammo working again.
