1978 - 1996 Big Bronco
Headlights
Old Mar 13, 2001 | 12:03 PM
AlM's Avatar
AlM
Headlights
Old Nov 16, 2002 | 06:59 AM
Bad 4X's Avatar
Bad 4X
Headlights
Does anyone know how to wire the headlights so that both the low beam and high beams come on when the switch is on high beam?
Old Nov 16, 2002 | 07:04 AM
Bad 4X's Avatar
Bad 4X
Headlights
I forgot to mention that I have a 1994 Bronco XLT
Old Nov 16, 2002 | 07:19 AM
alanscott's Avatar
alanscott
Headlights
I've read were someone did this and ended up melting the composite headlight bucket because of too much heat. Dang if I can remember where though. You might be better off with a good set of fog lights.
Old Nov 16, 2002 | 11:51 AM
steve83's Avatar
steve83
Headlights
[updated:LAST EDITED ON 16-Nov-02 AT 12:52 PM (EST)]Headlights are the R/Y wire going into the steering column. Low beams are the R/Bk coming out and hi are the LG/Bk. Just tie the R/Bk to the R/Y and you'll have normal low-beams, but when you switch to hi, you'll have all 4 filaments burning (like flash-to-pass).
But alanscott is right - it'll probably melt the housing and maybe overload the contacts in the main light switch.
