converting to manual choke?
Old Sep 26, 2010 | 06:33 AM
f100help's Avatar
f100help
73 f100 custom 302 2brl (motorcraft 2100/2150)
Is it as simple as going and getting a choke cable from the junkyard and installing a new manual choke carberator? or even simpler just the choke mechanism from the passenger side of the carb and the choke cable?
thoughts?
Old Sep 26, 2010 | 09:16 AM
hp246's Avatar
hp246
Manual choke is pretty simple. I have two set up with manual choke (both carbs were already setup). Do you self a favor and go to the hardware and pick up a clean cable. They're only a couple of buck. You'll be working with a cable that you can cut to the proper length and that you know will work.
Old Sep 26, 2010 | 09:46 AM
f100help's Avatar
f100help
something along the lines of a throttle cable for a lawnmower, just longer?
Old Sep 26, 2010 | 12:56 PM
hp246's Avatar
hp246
Actually, I've used a choke cable from the hardware for a lawn more application. They're usually way longer than necessary and you cut them to length. All you have to do is get from your mounting point through the firewall to the carb.
I think you can get them pretty cheap at any autoparts store too.
Old Sep 26, 2010 | 05:05 PM
sgtrwg's Avatar
sgtrwg
Just got a manual choke kit at the local Advanced Auto near me, $11.75. Took about 45 minutes to install it.
Works just fine.
Bob G
Old Sep 30, 2010 | 02:02 PM
70 Bronco TX's Avatar
70 Bronco TX
OK, I've got a question on this topic...and since it's still a relatively new post, I'll ask here:
I've got a Edelbrock 1405 carb with no choke--electric or manual. I need something this winter when it gets colder and don't want electric, which leaves me with a manual choke.
Can I get the cable and basic set up to attach the the choke plate on the carb....or do I need "extras" like the black cap, brackets, etc. like I see in the pic DanMan7's post from May 2008? Below is a pic.
I aske because I can get a simple Edlebrock cable that looks nice from a place like Summit, or get a kit from a place like AutoZone that seems to have the cap and other stuff. Maybe the cap is only if you are switching from electric to manual? Remember, I've got nothing right now. Maybe I get both the Edlebrock cable and the kit and merge parts together?
Old Sep 30, 2010 | 03:20 PM
hp246's Avatar
hp246
I believe the 1405 is a 600 cfm manual Choke carb. It should have the necessary attachment point for your choke cable unless someone has removed it. All you should need is the cable.
Old Sep 30, 2010 | 04:11 PM
70 Bronco TX
That's good news, thanks!
Old Sep 30, 2010 | 08:12 PM
shortboxd's Avatar
shortboxd
Mine has been manual choke with a 1405 carb for about 20 years- works great. All you should need is a cable. The 1405 is already setup for it.
Old Oct 22, 2010 | 09:24 PM
70 Bronco TX
Put the manual choke cable on (got the one from Edelbrock) and it is a 100% change for the better versus no choke at all. Got cold outside, started the truck up, pulled the choke and the engine smoothed out. This will be a nice change this year!
Old Aug 29, 2019 | 11:18 PM
fast68's Avatar
fast68
heya whats the part number for that edlebrock air cleaner assembly. if its fits on the 2100 and 2150 carbs? im in need of one for my stock original 2100 carb in my all originl untouched '73 F350 390ci. the original blue pained factory air cleaner assy. was totally rusted through and swiss-cheesed trash scrap condiiton non repairable or salvageable. at all hmmm. id rather go factory, but wont be able to use a full 14: one since i am swapping/converting to the large HEI distributor. hmm............... thx!
Old Sep 4, 2019 | 04:31 AM
Ozzie H.'s Avatar
Ozzie H.
Amazon has many varieties to make the job go better. The metal ***** seem sturdier than the plastic *****. Avoid sharp bends in the cable. I put a choke & throttle cable combination on my Motorcraft 4350. It works better than the auto choke ever worked.
Old Sep 4, 2019 | 09:18 AM
LARIAT 85's Avatar
LARIAT 85
When you get the choke set up, you will be much happier with your truck - especially when the weather is cooler. When set correctly, they can run almost as good as a fuel-injected vehicle.
The next thing you would need to address is that air cleaner. The one you have looks great, but that's about it. The stock Ford thermostatic air cleaner is better in many ways. Read this:
Air Cleaners - Gary's Garagemahal (the Bullnose bible)
herdfan75
Dec 5, 2016 09:19 AM
Viperfoxbat
Jul 25, 2016 10:56 AM
Sam's1967
Feb 9, 2016 08:28 AM
cadunkle
Dec 14, 2011 06:17 PM
JoeHarbourJets
May 17, 2011 03:03 PM
