broke down
Old Sep 26, 2010 | 03:16 AM
needtolearn's Avatar
needtolearn
broke down
new owner got an 03 6.0 just changed out the water pump ran fine for a couple of months then started overheating again need some help got to get it back on the road its my rig ride for work by the way it is a stock crew cab 4x4 short bed w/ 168000 miles
Old Sep 26, 2010 | 06:15 AM
bismic's Avatar
bismic
Please tell us more about the over heating. What is the indicator of this - does the dash gauge peg out, are you losing coolant, or something else? Does it overheat under normal driving or only when working hard (like towing)?
Do you have access to a code reader?
Are there any mods to the truck that you know of?
What coolant is in it and is the degas bottle at the proper level?
Old Sep 26, 2010 | 07:44 AM
Benchwrench's Avatar
Benchwrench
test oil cooler?
the dealer should be able to offer a good diagnosis if you can't figure this one out
Old Sep 26, 2010 | 07:49 AM
gearloose1's Avatar
gearloose1
Did you have other symptoms that led you to change out the water pump.
See the special instructions for changing coolant in the 6.0... it is not that simple.
Immediate guess: check EOT/ECT differential... if it is large... you bought yourself a new Oil and EGR cooler.
I assume you do not have exhaust gases / oil in coolant.
Old Sep 26, 2010 | 11:08 PM
needtolearn
normal driving dash gauge pegs out havent changed coolant but it is goldish yellow in color after you pull over and check the degas bottle there is little to no coolant once it cools off fluid level returns to full
Old Sep 26, 2010 | 11:33 PM
bismic's Avatar
bismic
Are you experiencing any loss of power?
Any DTC's?
Old Sep 26, 2010 | 11:52 PM
brickie's Avatar
brickie
Can you hear the cooling fan kick in when it overheats.
Flip4ford
Kansas Chapter
Jun 1, 2009 09:17 PM
tomtoc
1983 - 2012 Ranger & B-Series
Feb 5, 2007 06:32 PM
knapikmichael
21
Dec 6, 2006 10:48 PM
stebab
Apr 3, 2006 10:14 AM
tankblake
2004 - 2008 F150
Oct 3, 2004 06:28 PM
