Installing a ported housing, question.
Old Sep 25, 2010 | 02:28 PM
locknload223's Avatar
locknload223
Hi all, I'm installing RR's HPx, FRx. ATS ported housing, and 6.0 IC now. I can't find the instructions for shortening the wastegate rod on my 2000. I need to as the mounting flanges are definately different heights. Do I just turn the end of the rod back until I reach my desired measurement? I thought I read where you remove the rod and cut it down. Thanks. Taking a breather in the garage.
Old Sep 25, 2010 | 03:10 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
I just turned the end of my wastegate rod all the way in.
Old Sep 25, 2010 | 03:21 PM
locknload223
Thanks.
I already had the stock housing off and was installing the rear FRx fitting and effing dropped it back behind the turbo . I saw it for a second with a mirror but have no idea where it really is. Looks like I'm pulling the turbo off now. REALLY didn't want to do that.
Old Sep 25, 2010 | 03:33 PM
locknload223
GOT IT!!!!!!!!!!!!! Located and retrieved the fitting.
I learned years ago to walk away from something for a few minutes then get back on track.
Old Sep 25, 2010 | 05:56 PM
locknload223
OK, dumb question, once the new housing is mounted, how do I pull the wastegate arm over? It's super tight and because I adjusted it a 1/2" in it's 1/2" shy of fitting.
I used air to push the rod out but it doesn't move far enough.
Old Sep 25, 2010 | 06:51 PM
Izzy351's Avatar
Izzy351
I completely disconnected my wastegate when I had one. I suggest you get it where you can get the arm over it with air & call it good. Just keep an eye on your boost pressure & EGTs while you're towing. Be prepared to make some adjustments to it if you don't like how it ends up.
Old Sep 26, 2010 | 08:22 AM
locknload223
Thanks Izzy, that's what I was going to try next, I just wanted to make sure it was right. I do that today.
Old Sep 26, 2010 | 11:40 AM
locknload223
OK, I know you all have been waiting by your puters in suspense. Somehow the wastegate pin flipped back, is that the open position? No wonder I couldn't get it to attach. I was messing around and saw that it could flip forward. DUH! Hey, it's my first time playing with these. Granted, if I had pulled the turbo to begin with, I would have seen that. So I adjusted the arm back down to the 1/2" in mark and used a throttle linkage clip.
Now onto my HPx install.
jr2000sd
Feb 9, 2014 04:50 PM
Josh88Ford
18
Mar 13, 2013 06:56 AM
Woodsman_30350
Jun 25, 2008 07:58 AM
Brats
Dec 21, 2006 05:03 AM
medicpg
May 23, 2003 12:25 AM
