2003 6.0 missing/idling rough
Old Sep 30, 2010 | 03:20 PM
TChap6liter's Avatar
TChap6liter
Ok guys got her back together and it ran rough for a few minutes then ran smooth as ever. Could that have been air in the oil line from when I took it off?
Old Sep 30, 2010 | 03:23 PM
gearloose1's Avatar
gearloose1
Yup.
There is a standard procedure to purge air from the oil lines.
Old Oct 8, 2010 | 09:27 PM
TChap6liter
Well bad news.. truck is still running rough. Throwing code P0263 - Cylinder 1 contribution/balance fault. Already replaced my #1 injector. Anybody know what I should do next? Thanks.
Old Oct 8, 2010 | 10:03 PM
BLADE35's Avatar
BLADE35
I would check the FICM voltage should have 48 volts tech folder has the procedure. Have you checked fuel pres. If you changed that injector did you double check the torque on the injector hold down? I would also check the wire harness for chaffing or bent pins on the injector harness. Kinda strange it ran smooth for awhile after the high pres oil work and then started missing again I dont think its the high pres oil since its only one cylinder unless the one o-ring in the top of the injector is bad i dont think that oring is servicable either
Old Oct 8, 2010 | 10:17 PM
TChap6liter
I have a friend who is a diesel mechanic and he told me today about checking my voltage. And I have been needing to check my fuel pressure for a while, but havnt had a chance. I don't believe there are any bent pins on my injector harness. Thanks for the info though!
Old Oct 8, 2010 | 10:55 PM
BLADE35's Avatar
BLADE35
no problem I know it sucks when the problem isnt clear yet
Old Jan 4, 2011 | 06:00 PM
TChap6liter
Sorry i havn't posted back in a long time. I put 2 more injectors in and it ran good as new! turns out the people i took it to didn't run a full power/balance test and couldn't tell me exactly what was wrong.
YouTube - 2003 F350 6.0L with new injectors
Old Mar 2, 2011 | 12:37 AM
riverstroker04's Avatar
riverstroker04
to the OP. Did they replace the #1 inject two times? I am having the same prob after my EGR and ARP job, not all the time just every now and then.
MAN just watched your vid that sounds BA
Old Mar 2, 2011 | 11:45 AM
mblanken881's Avatar
mblanken881
I love the sound of your truck and want the same. What do you have done to your exhaust?
Old May 28, 2015 | 06:50 AM
harleytruckjoe's Avatar
harleytruckjoe
hard start
I have a 04 ford 6.0. I have to wait on fuel to pump up before starting the truck in the morning. It is like the fuel leaking back. Had the regulator rebuilt any suggestions
Codeman894
Apr 4, 2024 09:52 PM
Codeman894
Apr 29, 2017 02:19 PM
roostonu
Jun 15, 2016 04:30 PM
big-head
Aug 3, 2015 10:20 PM
6.0ford67
Dec 5, 2014 06:20 AM
