engine mounts and pedestals
Old Sep 24, 2010 | 02:55 PM
mjcrowson's Avatar
mjcrowson
hate to beat a dead horse believe me but i've done the search and asked the question before and cant seem to get an answer. Im in the process a swapping a 460 into my 71 F250 4x4 and i have all i need except for one thing. Will my pesdestals work or do i need to find aftermarket ones? I know about the mounts, pan and pickup, but i just need to know about the pedestals. thanks in advance
Old Sep 24, 2010 | 08:53 PM
dbdbb's Avatar
dbdbb
I have swapped many engines in 67-79 Ford f100-250 4x4's and all I ever did was move the frame perches, sometimes the holes line up and some times they don't, If they didn't I just welded them to the frame. I have never had a problem with this method.
Old Sep 25, 2010 | 12:35 AM
mjcrowson's Avatar
mjcrowson
thank you sir i like that answer
Old Sep 25, 2010 | 10:29 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
I know one of the 67-72 vendors sells the kit to install the 429-460 into our trucks. I think it's Dennis Carpenter who has the kit.
Old Sep 27, 2010 | 01:53 AM
RichS2659's Avatar
RichS2659
If I remember correctly from an answer by Number Dummy, he said that the 460 towers for a 460 equipped 75-79 2wd are the same as the towers for a 351M/400 2wd, then it can be correlated that the 4wd 351M/400 towers can be used for a 460 4wd?
Old Sep 27, 2010 | 02:04 PM
mjcrowson's Avatar
mjcrowson
that makes sense mine had FE power to begin with though. on the L&L site they have a kit for $275 that has the towers and mounts, but also you can just buy the mounts and in the description it says that 4wd use the original towers. i think i will buy the L&L mounts and go for it and if necessary i can double back and get the towers also
Franko72
23
Nov 22, 2012 01:17 PM
grasfarmr73
Oct 31, 2012 01:33 PM
alvin431
Feb 19, 2011 03:26 PM
ldfry001
Mar 13, 2008 09:54 AM
Want2Bfordman
Apr 10, 2004 10:43 PM
