need help 96 powerstroke
Old Sep 24, 2010 | 12:07 PM
powerstroke 96's Avatar
powerstroke 96
posting for a friend. 1996 7.3 powerstroke. truck will start up and run till engine temp reaches 180, then it will blow grayish smoke and shut down, will not restart till it cools of, then does the same thing again. any help please. truck is mostly stock, 3" dp 4" exhaust, air intake and tuner
Old Sep 24, 2010 | 12:19 PM
427 fordman's Avatar
427 fordman
Has he been in a lot of rain/water? Could be water in the IDM, wag. Easy check, unbolt from drivers inside fender, unplug it and shake it to see..
Old Sep 24, 2010 | 02:48 PM
powerstroke 96
i wil pass that along to him. thanks brent
Old Sep 24, 2010 | 02:54 PM
Action4478's Avatar
Action4478
Sounds like classic IPR O ring bad...Its a cheap test . Take it out and look at it...
Old Sep 24, 2010 | 06:41 PM
427 fordman
may want to go with what Rick said, he's smarter than me...
Old Sep 24, 2010 | 07:34 PM
tjbeggs's Avatar
tjbeggs
Yep what Rick said. Classic symptom of IPR o-rings
Old Sep 24, 2010 | 08:29 PM
powerstroke 96
No water in the idk. And the o-ring looks good. Now what?
Old Sep 24, 2010 | 08:34 PM
fordpride's Avatar
fordpride
Change em and put it back in
Old Sep 24, 2010 | 08:59 PM
Action4478's Avatar
Action4478
If the IPR o Ring is not the problem . you may have an injector O ring issue...
Old Sep 24, 2010 | 09:31 PM
powerstroke 96
May have it fixed. Replaced the ipr o-ring and the fuel filter o-ring. Test drive time
Old Sep 24, 2010 | 10:01 PM
powerstroke 96
Not fixed. Shuts off right at 185. Does it have a second temp switch for the CPU?
Old Sep 25, 2010 | 04:19 PM
powerstroke 96
need more help. i think we replaced the wrong o-ring. where is the ipr?
Old Sep 25, 2010 | 04:27 PM
Action4478's Avatar
Action4478
https://www.ford-trucks.com/forums/9...ot-solved.html
Old Sep 25, 2010 | 05:52 PM
powerstroke 96
thanks. got it out. one o-ring has a small nick in it but not torn do you think that is the proplem? we r going to replace them while we r in here anyways. but no one has them till tues.
Old Sep 25, 2010 | 05:56 PM
Action4478's Avatar
Action4478
Could well be ...
