Return Line Kits
Old Sep 22, 2010 | 11:33 PM
polarismuddman's Avatar
polarismuddman
Return Line Kits
Are there any advantages between the older and newer return line kits? Looking to maybe buy a set......Thanks on any input.
Old Sep 22, 2010 | 11:37 PM
rupejosh's Avatar
rupejosh
what do you mean by older and newer?
Old Sep 23, 2010 | 12:08 AM
polarismuddman
The injector hats have different designs.
Pensacola Fuel Injection | Worlds #1 Diesel Rebuilder - FORD 6.9L - 7.3L :: INSTALLATION KITS
Old Sep 23, 2010 | 02:00 AM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
I am a newbie and I don't know yit from yinola, but I bought a return line kit from Kragen Oriley for 70 bucks and installed it myself with relative ease and it is working great. The kit includes fuel line, caps which were configured a little different but fit fine, clamps, O rings, and what I think were injrctor seals, but I didn't pull mine. Good luck.
Old Sep 23, 2010 | 02:16 AM
saltbranch's Avatar
saltbranch
I bought the Orings @ ford for next to nothing, cant remember the exact but it was cheap. I used bulk fuel hose/ cut it to length for the jumper lines etc. I was in it for around 20.00 or so
Old Sep 23, 2010 | 03:04 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
And it won't last long ...
Buna o-rings - Harden after a few heat soaks - Don't disturb them or they'll leak air!
Gasoline hose - swells and deteriorates!
Old Tees - brittle and break!
Did you use worm drive hose clamps as well ...
A headache on it's way!
Cheap isn't always cheap!
Doing it right costs about $40 bux!
89-94 7.3L Injector Installation Kit - Pensacola ... about $30 delivered! ($29.94)
Viton Return O-Rings - McMaster-Carr Item 9464K24 ... about $10 delivered. ($10.61)
A package that will last a lot longer even if disturbed!
The hose is Diesel rated.
The Viton o-rings are impervious to Diesel and can withstand the temperature for a lot longer without hardening and leaking air!
-Enjoy
fh : )_~
Old Sep 23, 2010 | 12:19 PM
saltbranch's Avatar
saltbranch
Did it the same way on several hotshot trucks in the past, most of these trucks ran 80-100k miles per year, no problems. Yes to the worm gear clamps, when thats all that could be found at the time. Amazingly it worked!
Old Sep 23, 2010 | 01:05 PM
Festus Hagen
Methanoholic
Yea, That is amazing ... Even harder to believe!
Worm screw clamps do not squeeze all the way around, therefore not resulting in an air tight seal!
You can use Buna o-rings, thats what the factory used ... BUT do not disturb them after a couple heat soaks or they'll leak air!
-Enjoy
fh : )_~
hwy92truckn
Jan 6, 2013 07:10 AM
hondarider10
May 25, 2012 10:20 AM
Dodge/Cummins
15
Oct 15, 2010 11:22 AM
bluthunder
Sep 15, 2007 03:36 PM
Meatwagon
Jul 10, 2007 07:33 PM
