Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
HF pipe bender am I missing something?
Old Sep 22, 2010 | 10:49 PM
karljay's Avatar
karljay
I bought the Harbor Freight pipe bender, it's the 16 ton manual one.
16 Ton Hydraulic Pipe Bender
I've need to make the header back part of the exhaust on at least 3 cars/trucks... so I figured I'd just buy this...
So I need to bend something... Took a fence post and cut about 18" and bent it about 30 deg... the results were less than impresive... it was flat at the outside of the bend and would really suck if it was something that needed to flow.
I've seen the video on youtube where someone takes sand and duct tape... fills the pipe with sand and then bends it and it comes out very nice / almost like mandrel bent... but I really expected a better bend out of this... I tried both the 2.0" and 2.5", the results were about the same.
Am I doing something wrong here?
Old Sep 23, 2010 | 12:37 AM
Ford_Six's Avatar
Ford_Six
That's just the way these benders work. I have used the sand trick before, and it works very well, but the pipe must be completely filled and you need to go slowly. You can use an expandable rubber freeze plug in the ends of the pipe to make a bit better of a seal than duct tape.
Old Sep 23, 2010 | 06:33 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
That's why it's called a "pipe" not tubing bender. Sold mine at a yard sale two weeks ago for $25 to get it out of my way.
northerndave
25
Jul 11, 2012 07:42 PM
arthurfelter
Aug 10, 2011 09:36 AM
fishmanndotcom
Offroad & 4x4
Nov 21, 2006 09:03 PM
Jesse R
Garage & Workshop
Feb 8, 2005 02:30 PM
