460 questions
Old Jan 5, 2015 | 09:36 PM
71Future5er's Avatar
71Future5er
Originally Posted by cathode
I'm in the midst of this same swap now with my '79 so I've done a lot of reading over the past 6 months or so. The following pertains to my '79 swap, I don't know what year you're working on but that may affect this info too.
Blocks on the 460 changed with a '79 casting to an externally balanced engine vs the early internally balanced engine. Either is perfectly usable, most people seem to prefer the early style internally balanced versions. Also check casting numbers on the heads. Some good ones include C8VE, C9VE, D0VE and D3VE (the latter is the later style head with bigger chamber but still good street potential).
As for swap parts, you will want the rear sump pan as mentioned above and you can use truck manifolds including some mid-80s manifolds. Alternatively you can buy a set of L&L headers (there are a few other brands too) but they'll run around $450-500. Do not notch the frame to fit a car manifold on there.
Motor mounts are available for just over $100 from L&L that will allow things to fit without having to move the transmission anywhere. You'll want power steering and alternator brackets which can also be purchased new from L&L for around $100 each, or you can search for van brackets which as I understand, fit right in.
There are lots of site detailing the swap out there. Here's one:
1973-1979 Ford Truck 460 V-8 Swap
Thanks for the info. I was just going to post these same questions. I always wanted to know about the different head castings.
Old Jan 5, 2015 | 10:18 PM
79FordBlake's Avatar
79FordBlake
I to will be doing the 460 swap soon but in a 78 Bronco. My 460 came out of a 1974 Lincoln.
I'm using factory 460 manifolds out of a 1979 F150 2wd as well as alternator bracket, a/c bracket, power steering bracket.
I decided to keep the stock cast iron 4 barrel manifold and have a Edelbrock 600 electric choke carb on it.
Runs fine on the engine stand we will see how it does in vehicle. I have a 750 carb as well but I don't think it will need it. A simple metering rod and jet change on the 600 will get me where I need to be I believe if its even needed.
I got my engine mounts from LEB(Left Eye Blind Racing).
I ordered the Ford Racing rear sump oil pan kit and a stock volume/pressure Melling oil pump.
Old Jan 6, 2015 | 12:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Ronzi
If your 76 F250 does have a 351M in it (351/400's did not come in those trucks) then it will be just as much trouble if not more to put the 390 in it.
If your 76 is auto the 460 will bolt up to your trans. The 390 will require a different trans.
Only V8 available in 1968/76 F100/250 4WD: 360 2V, but it's almost the same as the 390. The block/heads and the bore are the same (4.05"), the only difference is the stroke. 360 = 3.50" - 390 = 3.78."
To convert a 360 to a 390 requires the 390 crank, rods and pistons....that's it!
The C6 used with FE engines will not work with any other engine size.
NOTE: There were TWO different 460's used in 1979: Block casting numbers D1VE-6015-AB & D9TE-6015-AB
D1VE is internally balanced, D9TE is externally balanced. The flywheel (flexplate) and harmonic balancer are specific to either.
There were no before/from production dates or serial numbers, the block casting number must be known to get the correct parts.
Old Jan 6, 2015 | 04:06 PM
gatorfor88's Avatar
gatorfor88
Both swaps will require things. The 460 swap is much more common.
What he said. First thing to do is make sure what engine you actually do have.
7379ford
Dec 17, 2016 03:49 PM
wyckedcombo17
Sep 12, 2013 12:52 PM
vinf100
1978 - 1996 Big Bronco
Oct 2, 2011 09:28 AM
torquemeister
Engine Swaps
Jan 23, 2010 01:20 PM
igod69m
Jan 16, 2010 09:15 PM
