Rear Springs
Old Sep 21, 2010 | 08:56 PM
hotfalcoon's Avatar
hotfalcoon
Lightbulb Rear Springs
I was planning on using '75 f-250 rear springs on my '57 because they are the same width and length as the stock springs, but I realized the '75 springs are equal length from center to the eye on both sides which would move my axle off center a couple of inches because the stock springs are longer in the rear and a little shorter up front from the tie bolt. Glad I figured this out before putting it together that way. I will use the '75 front springs but will be using OEM in the back.
Old Sep 22, 2010 | 12:01 AM
lvin4jc's Avatar
lvin4jc
Yeah, that would have been a frustrating day for sure. But I think you still get an A for figuring out that you could even use the later springs for the front in the first place
Old Sep 22, 2010 | 07:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1957/72 F100 2WD rear springs interchange.
24" > > eyebolt < < 28" / 2 1/4" wide.
Not only do the springs interchange...in 1965, Ford replaced B7C5560A (5 leaf) with C5TZ5560A (5 leaf).
Old Sep 23, 2010 | 06:52 PM
hotfalcoon's Avatar
hotfalcoon
Thanks for the info!
Under Pressure
Jan 13, 2018 06:37 PM
lovestrucks
Mar 2, 2012 03:01 PM
Grubbworm
Apr 21, 2011 09:56 PM
Grubbworm
Apr 21, 2011 12:35 PM
dots
Feb 28, 2005 11:05 AM
