Sponsored by: Kumho
Coil spring questions
Old Apr 20, 2011 | 09:16 AM
Grubbworm's Avatar
Grubbworm
I have a 1985 Ford F150, 4x2 (2wd), 300/6cyl., MT, 3.08 rear, 31x10.50x15 tires on 8.5” wheels. I use the truck mainly for camping, fishing, Home Depot runs, and the occasional dump run. I am looking to raise the front of the truck to be more level with the rear by installing some new coil springs. I am considering installing the Moog CC822, CC824, CC844, or the CC844S’s. I also have a 2” block lift kit for the rear springs (already have) and I am considering installing that as well (I will upgrade the U-bolts). I am not really looking to raise the rear of the truck, but am more interested in keeping the rear from sagging under load. I would prefer if the truck were to sit level while under load. I am also considering putting some new 32x11.50x15’s on my 8.5” wheels once the truck is raised. I know that I will need an alignment once I am finished, but need to know if I might run into any problems with any of my choices or the alignment.
Product ID:
MOOG-CC822
Manufacturer: MOOG
Front Variable Rate Coil Springs
<table class="MsoNormalTable" style="width:100.0%;mso-cellspacing:1.5pt;mso-yfti-tbllook:1184" border="0" cellpadding="0" width="100%"> <tbody><tr style="mso-yfti-irow:0;mso-yfti-firstrow:yes;mso-yfti-lastrow:yes"> <td style="padding:.75pt .75pt .75pt .75pt" valign="top"> <table class="MsoNormalTable" style="width:337.5pt;border-collapse:collapse;border:none;mso-border-alt: outset lightgrey .75pt;mso-yfti-tbllook:1184" border="1" cellpadding="0" cellspacing="0" width="450"> <tbody><tr style="mso-yfti-irow:0;mso-yfti-firstrow:yes"> <td style="border:inset lightgrey 1.0pt;mso-border-alt:inset lightgrey .75pt; padding:.75pt .75pt .75pt .75pt">
End 1 Type
</td> <td style="border:inset lightgrey 1.0pt;border-left:none;mso-border-left-alt: inset lightgrey .75pt;mso-border-alt:inset lightgrey .75pt;padding:.75pt .75pt .75pt .75pt">
End 2 Type
Inside Diameter
Bar Diameter
Install Height
Load
Spring Rate
Free Height
</td> </tr> <tr style="mso-yfti-irow:1;mso-yfti-lastrow:yes"> <td style="border:inset lightgrey 1.0pt;border-top:none; mso-border-top-alt:inset lightgrey .75pt;mso-border-alt:inset lightgrey .75pt; padding:.75pt .75pt .75pt .75pt" valign="top">
Pig Tail
</td> <td style="border-top:none;border-left:none;border-bottom:inset lightgrey 1.0pt; border-right:inset lightgrey 1.0pt;mso-border-top-alt:inset lightgrey .75pt; mso-border-left-alt:inset lightgrey .75pt;mso-border-alt:inset lightgrey .75pt; padding:.75pt .75pt .75pt .75pt" valign="top">
Pig Tail
4.000
.718
13.00
1230
366
16.38
</td> </tr> </tbody></table> </td> <td style="padding:.75pt .75pt .75pt .75pt">
Product ID: MOOG-CC824
Manufacturer: MOOG
<table class="MsoNormalTable" style="width:337.5pt;border-collapse:collapse;border:none;mso-border-alt<img src=" http:="" images.ford-trucks.com="" forums="" images="" smilies="" redface.gif"="" alt="" title="Embarrassment" smilieid="3" border="0"><tbody><tr style="mso-yfti-irow:0;mso-yfti-firstrow:yes"><td style="border:inset lightgrey 1.0pt;mso-border-alt:inset lightgrey .75pt; padding:.75pt .75pt .75pt .75pt">
End 1 Type
End 2 Type
Inside Diameter
Bar Diameter
Install Height
Load
Spring Rate
Free Height
Pig Tail
Pig Tail
4.000
.718
13.00
1442
366
16.94
<table class="MsoNormalTable" style="width:337.5pt;border-collapse:collapse;border:none;mso-border-alt<img src=" http:="" images.ford-trucks.com="" forums="" images="" smilies="" redface.gif"="" alt="" title="Embarrassment" smilieid="3" border="0"><tbody><tr style="mso-yfti-irow:0;mso-yfti-firstrow:yes"><td colspan="8" style="border:inset lightgrey 1.0pt;mso-border-alt:inset lightgrey .75pt; padding:.75pt .75pt .75pt .75pt">Product ID: MOOG-CC844
Manufacturer: MOOG
</td> </tr> <tr style="mso-yfti-irow:1"> <td style="border:inset lightgrey 1.0pt;border-top:none;mso-border-top-alt: inset lightgrey .75pt;mso-border-alt:inset lightgrey .75pt;padding:.75pt .75pt .75pt .75pt">
End 1 Type
</td> <td style="border-top:none;border-left:none;border-bottom:inset lightgrey 1.0pt; border-right:inset lightgrey 1.0pt;mso-border-top-alt:inset lightgrey .75pt; mso-border-left-alt:inset lightgrey .75pt;mso-border-alt:inset lightgrey .75pt; padding:.75pt .75pt .75pt .75pt">
End 2 Type
Inside Diameter
Bar Diameter
Install Height
Load
Spring Rate
Free Height
</td> </tr> <tr style="mso-yfti-irow:2;mso-yfti-lastrow:yes"> <td style="border:inset lightgrey 1.0pt;border-top:none; mso-border-top-alt:inset lightgrey .75pt;mso-border-alt:inset lightgrey .75pt; padding:.75pt .75pt .75pt .75pt" valign="top">
Pig Tail
Pig Tail
4.000
.812
12.75
1557
630
15.40
<table class="MsoNormalTable" style="width:337.5pt;border-collapse:collapse;border:none;mso-border-alt<img src=" http:="" images.ford-trucks.com="" forums="" images="" smilies="" redface.gif"="" alt="" title="Embarrassment" smilieid="3" border="0"><tbody><tr style="mso-yfti-irow:0;mso-yfti-firstrow:yes"><td colspan="8" style="border:inset lightgrey 1.0pt;mso-border-alt:inset lightgrey .75pt; padding:.75pt .75pt .75pt .75pt">Product ID: MOOG-CC844S
Manufacturer: MOOG
End 1 Type
End 2 Type
Inside Diameter
Bar Diameter
Install Height
Load
Spring Rate
Free Height
Pig Tail
Pig Tail
4.000
.812
13.00
1759
629
15.79
Old Apr 20, 2011 | 06:11 PM
Ford_Six's Avatar
Ford_Six
Well, if you pick up the front end you will have to deal with camber issues due to the twin I beam front end.
To keep the rear from sagging under load you will need stiffer springs or some sort of assist like air springs.
Old Apr 21, 2011 | 12:35 PM
82Blue's Avatar
82Blue
It's so easy to add leafs to your rear, and for the front, get some picks, any spring that's not part of a lift kit is going to set the truck close to stock ride height. Remember longer coils lift, stiffer ones don't and if you go with a stiffer spring on the front its going to lake it ride rougher, airing kits for your truck cost more than a 2 inch lift
bismic
Nov 23, 2016 07:43 AM
trippn4re
23
Jun 2, 2014 04:16 PM
99ExpyProblems
Dec 11, 2013 08:45 PM
Dlasure2
Aug 15, 2013 02:12 PM
Grubbworm
Apr 21, 2011 09:56 PM
