Aerostar Ford Aerostar
power steering fluid level
Old Feb 20, 2003 | 03:58 PM
chrisw8925's Avatar
chrisw8925
Inherited a 93 aerostar 4.0 with no owners manual. Can anyone describe the proper method for checking the power steering fluid level?
Old Feb 20, 2003 | 04:14 PM
aerocolorado's Avatar
aerocolorado
The power steering reservoir is equipped with a built in dipstick, one side marked "COLD" the other "HOT". Just fill to level indicated depending on the engine condition. Better to run just slightly underfilled than overfilled. Usually on the 4.0 reservoir the level is just barely visible when looking in from above.
Old Feb 20, 2003 | 04:16 PM
chrisw8925's Avatar
chrisw8925
Should I check when running or with the engine off?
Old Feb 20, 2003 | 04:29 PM
aerocolorado
Check with the engine off. Otherwise, there is a very busy serpentine belt whirring away just below your forearm when reaching for the P/S reservoir that could inflict serious injury.
Old Feb 27, 2003 | 09:01 PM
clydes270's Avatar
clydes270
Check it running. I do about every month or so.
Old Feb 28, 2003 | 09:45 AM
aerocolorado
I suggest you Read your owner's manual as this is very poor advice.
Old Feb 28, 2003 | 01:39 PM
clydes270's Avatar
clydes270
How do you see air bubbles? While its OFF.
Also, how do you vacuum bleed the PS fluid?
When, its off.
I think not.
Old Feb 28, 2003 | 01:44 PM
clydes270's Avatar
clydes270
You're right.
I forgot to disconnect the battery.
crazyrwe
2009 - 2014 F150
Nov 18, 2013 11:18 PM
TGenolcyC66
2004 - 2008 F150
Jun 15, 2011 07:22 AM
shark1979
Apr 2, 2009 08:37 PM
fred_79f250
General Automotive Discussion
May 6, 2007 10:57 PM
zorro
May 31, 2006 03:58 PM
