1st DEF Refill VIDEO
Old Sep 20, 2010 | 12:58 PM
Help I M Stuck's Avatar
Help I M Stuck
Good info..exactly what I wanted to know.
Old Sep 20, 2010 | 05:37 PM
PowerStrokeHD's Avatar
PowerStrokeHD
Originally Posted by rickatic
While I agree that the countdown is intelligent, I have seen a post that says the dealers can actually see percentage left in the tank. If they can in fact see this, why not put it on the display?
The DEF tank uses a real simple electrode type level sensor that only measures 3 positions, so there is no real way to provide a accurate DEF level like you see with fuel level which uses a float system. The electrodes on the sensor are arranged vertically to provide a high, middle, and low level signal and a fourth electrode runs the length of the sensor to act as the ground. When the tank is full, the DEF (which is a good conductor of electricity) closes a circuit between all three level electrodes and the ground electrode, indicating the tank is full. As the DEF is consumed, the level drops and uncovers each electrode in sequence. The PCM calculates the DEF level based on these signals.
Old Sep 20, 2010 | 05:39 PM
EpicCowlick's Avatar
EpicCowlick
Thanks. Come to think of it, a float system wouldn't work too well inside a block of ice. See, Ford was thinking when they implemented that.
Old Sep 20, 2010 | 05:53 PM
roadkingfl's Avatar
roadkingfl
Epic great job buddy........the 2 1/2 gal jugs I bought brought a nifty hose attached to the mouth of the jug........no funnel required.......but hey look at it this way, you wouldn't of tasted the urea.
Old Sep 20, 2010 | 08:41 PM
fixdent's Avatar
fixdent
Ya, I wish it had a more accurate guage to tell how much was in there. I just top it off whenevery I feel like it. last time it took 1 gallon after 2200 kms (1500 miles)
I have yet to let it go to "less than half" reading.
Gordon
Old Sep 20, 2010 | 09:32 PM
jtsteelman's Avatar
jtsteelman
I just purchased the 2.5 Gal Peak bottle for $11 with spout. Hopefully the spout is a little more convenient than the funnel. Certainly would be nice to have a gauge or graphic indicator for long trips.
Old Sep 20, 2010 | 10:52 PM
PHXDiesel's Avatar
PHXDiesel
Ok who gave Epic the freakin' camera?!?!
Just kidding, great vids!
firebus
6.7L Power Stroke Diesel
22
Mar 7, 2022 07:44 PM
swarf_rat
Oct 28, 2016 01:50 PM
EpicCowlick
47
Aug 30, 2016 12:06 PM
EpicCowlick
38
Dec 16, 2011 07:15 PM
Nipperdog
Oct 23, 2010 01:00 PM
