need help
Old Sep 19, 2010 | 02:53 PM
kerim1's Avatar
kerim1
need help
hi i have a 2000 expy 4.6 with 136xxx miles
i live in connecticuit and need to pass emissions but i have a PO401 code
i just replaced the egr valve and solenoid yesterday but today the same code back on.
is there anyting else i could check
please help
Old Sep 19, 2010 | 03:12 PM
fordinlinesix's Avatar
fordinlinesix
Yup, change the EGR valve position sensor. That is usually the culprit because exhaust plugs up the sensor.
Old Sep 19, 2010 | 05:08 PM
alloro's Avatar
alloro
Originally Posted by kerim1
i live in Connecticut
You should update your profile, it says you're in Florida.
Old Sep 19, 2010 | 05:40 PM
kerim1's Avatar
kerim1
ok i just replaced the egr pressure sensor i will see tomorrow if the code comes back or if im lucky.
sorry i forgot to update my profile
Old Sep 20, 2010 | 08:26 PM
kerim1's Avatar
kerim1
ok my code came back on today after replaceing egr valve, egr solenoid, and egr pressure sensor.
is there anyting else i can check?
what kind of hoses or tubes can i check?
thank you
Old Sep 20, 2010 | 10:04 PM
alloro's Avatar
alloro
is there anything else i can check?
When you had the EGR valve off did you clean the ports behind it and make sure they weren't blocked or restricted?
Old Sep 20, 2010 | 10:40 PM
kerim1's Avatar
kerim1
yes i did. are there any hoses i could check?
Old Sep 20, 2010 | 10:59 PM
pdqford's Avatar
pdqford
Yep. The hoses that plug into the DPFE.
And the EGR ports in the intake manifold.
bielenbergr
Aug 21, 2011 05:31 AM
f.100
Jul 18, 2010 03:16 PM
broncorif
Mar 23, 2010 06:20 PM
2behad
New Member Introductions
Sep 8, 2009 02:02 PM
