Plug and play! Just need to figure out where to put it. I just velcro'd mine to the lower part of the dash near the OBD port.
Then print out the xgauge codes from their website and add different features. Use the Ford 6.0 section. Be accurate when entering the codes. Ford's are "CAN" Have fun with it!
You are welcome. It's a fun toy. I always leave ECT and EOT up and running. Then when I'm towing I add TFT (tranny temp) Then I switch to IPR and ICP for watching things. My Boost isn't working right, it goes negative around 21, so not sure why. I also check my volts every once in a while.
The website has pictures of where to mount them, there is also a mount for above the rear view mirror.
Have fun! Don't stress the ECT EOT spread unless you are running empty down the highway. From what I've heard, that is where Ford looks for the 15 degree difference.
Installed mine thins week and its very easy. I do have a question for someone that might know. Is there a program code for ETC and EOT because I dont think I saw that one in the book or on their web site. I have a 05 F350 6.0
Boost isnt running right.--------Have you checked you EBP sensor? Also on the Scan Gauge how is your EBP reading?
i got mine mpg was off so i called scangauge and they are sending me a new unit more specific to my truck they are on back order 3-4 weeks. i used the cansf catagory and the 6.0 catagory.mine didnt report ebp will see about the new unit but i doubt it will work then either. do you guys program from any of the other catagorys
What is better; scan gauge or edge insight? Scan gauge cost is a lot less.
IMO, price is the key factor in determining which one to get. I chose the ScanGauge due to it's price and features compared to the price and features of the Edge Insight. I couldn't see paying 80 to 140% more for the Edge for monitoring the basic functions of my 6.0. Sure it's plain and simple, but that's what I like. Makes things easier inside this old head with shrinking gray matter.
As far as EGT, I can add a separate gauge for around $120, and my FP gauge should be here tomorrow.
___________________________
Vic
2006 F250 6.0, CC, Lariat, High Idle mod, Dieselsite coolant filter, ScanGauge II w/BlendMount
besides BLADE35's experience with the MPG feature how is it working for the rest of you? accurate?
I love mine bought mine right after i got my truck lot cheaper and yes the MPG is very close to gather.On the highway i get 19.5 with scangauge i came out with 19.0 but i only did it one time.
