TPMS...relearn a lower pressure?
Old Sep 21, 2010 | 05:51 PM
vrsc's Avatar
vrsc
Originally Posted by EpicCowlick
Are you talking about the TPMS retrain procedure? I've done it so many times I'm sure I mumble it in my sleep. Ignition on > flasher three times > let pressure out of driver front tire til the horn sounds > passenger front > passenger rear > driver rear > horn sounds once > acknowledge the information display > refill tires to desired pressure above 65 psi.
I fought with this trying to get it to learn lower pressures but eventually gave up. 65 and above keeps the low pressure warning from re-occuring.
Yep, but I'd rather have my dealer do it and record my issues with FMC
Old Sep 21, 2010 | 07:53 PM
Zookie400's Avatar
Zookie400
Originally Posted by vrsc
No scan tool was provided with the 2011. There is another reset procedure that takes it's place. You'll find this procedure in the manual but good luck, it's a PITA. Going to the dealer was much easier for me
that is the retrain procedure for relearning tire location, should you rotate your tires or replace the sensors. it does not reset the pressure set point.
Old Sep 29, 2010 | 09:12 PM
rocdril's Avatar
rocdril
Anyone have to go back to the dealer yet for this? I have 11,000 miles, and the light has been on for the last 2,000. I have retrained the system at leats 5 times and I am running 80 in the back and 60 in the front.
Old Sep 29, 2010 | 09:40 PM
RadRick's Avatar
RadRick
Just curious, could you just buy the sensors from another vehicle that runs a lower tire pressure, like an F-150, and have them installed, or do they have to be the correct part for the computer to recognize them?
Old Sep 29, 2010 | 09:46 PM
FORDTUF1's Avatar
FORDTUF1
We've talked about you can't go under 63 or 62 or so. So are you saying you've been running 60 in the front all this whole 11,000 miles and now the last 2000 or so it's giving you problems? If so then you may have some that might be just a bit off calibration, I wish mine would let me run even 4 or 5 less pounds.
Maybe since the cooler weather has come you're down to 58 and maybe it's seting off, dunno.
Old Sep 29, 2010 | 10:59 PM
kper05's Avatar
kper05
The TPMS is the only thing I don't like.
I'll figure it out eventually but I've never had tire monitoring before so I currently think it's annoying when I've made my own safe decisions in years past.
I even had my dealer reset it and it came back on driving home from the dealer with 65 front and 70 rear so IDK how to explain that.
I'm going to put a few additional pounds in the front (cold) and I bet that will solve it.
Drives me crazy...
Old Sep 30, 2010 | 04:24 AM
rocdril's Avatar
rocdril
I could of swore my door sticker says 60psi front, 80psi rear. Maybe Im wrong.
Old Sep 30, 2010 | 07:51 AM
FORDTUF1's Avatar
FORDTUF1
Is yours a 4wd or 2?
On the subject of switching TPMS from other trucks, Ford dealer manager says it won't work. They say the 20" rims have coded sensors for 80 psi and the 18 and such have them coded for 65 on continentals, so the truck computer has to recognize the digital signature of the one preset for 80 psi on mine.
Old Sep 30, 2010 | 08:20 AM
rocdril's Avatar
rocdril
4WD, and I just checked the door sticker again. It says 65psi in the front, not 60 psi, 80 psi in the rear. SO....... this has probally been MY problem all along.
Old Oct 12, 2010 | 12:41 PM
BTyner41's Avatar
BTyner41
Ok so I have the 18" wheels with the Conti's. I have been watching this thread for a while now and finally decided to go out and check my pressures. All tires are at 51.5 psi this morning with no warnings. Have they made some changes to the system since first introduced? My truck was built the last week of August.
Old Oct 18, 2010 | 07:30 PM
PalouseSD's Avatar
PalouseSD
Is the required pressure information a function of the TPMS sensor OR is it set in the computer? I would think its stored in the computer.
What are people doing when they put after market wheels on and want to keep the old wheels for dedicated winter tires?
Old Oct 18, 2010 | 07:57 PM
720Deere's Avatar
720Deere
They should call this the PITA system not TPMS! Ambient temps dropped to 42 here this morning and my tires set at 66 psi previously must have dropped low enough to set off the idiot alert. I came home from work today, checked all the tires and set them to 68 psi. After driving 10 miles the stupid light wouldn't go out. When I got back home tonight, I did the relearn and that reset it finally.
Each and every tire was at 62 psi after the reset. I put them back at 68 and we'll see what happens now.
Old Oct 18, 2010 | 09:34 PM
  #28
PalouseSD's Avatar
PalouseSD
One thing to note is that some tire shops use Nitrogen rather than air. The reason for this is that Nitrogen is less affected by temperature changes, that is, as the tire heats up while driving, the tire pressure increases at a lower rate with nitrogen than it does with air. This is why race cars run nitrogen. Also, the nitrogen molecule is relatively large and is less prone to leak down. When you see a tire with a green valve stem cap it means that the tire was filled with nitrogen. It would be interesting to see if nitrogen would help with these TPMS problems.
Old Oct 21, 2010 | 08:17 AM
  #29
GMUGNIER's Avatar
GMUGNIER
Ok - I have confirmed that you CAN change the TPMS to ANY PSI setting you wish - I was at a buddy's shop yesterday and he has the latest ford computer, with all the updates. I was able to look at all the settings and you can modify it - also you can change the front and back to different pressures if you like - I noticed the pressure went from the low teens to over 90lbs. So if you know someone at the dealer, or know someone with the FORD computer you can modify the settings...
Old Oct 21, 2010 | 08:51 AM
  #30
EpicCowlick's Avatar
EpicCowlick
That's good to know. Next time I'm at my dealer I'm going to have them set the pressure to 50 psi.
ctfl
Apr 26, 2018 10:03 PM
wasmblad
May 21, 2015 10:41 AM
Z06PSI
May 26, 2014 11:57 AM
98woody
6.7L Power Stroke Diesel
Aug 19, 2013 03:14 PM
98woody
Aug 14, 2013 05:58 PM
