TPMS on 2005 Navigator
Old May 25, 2014 | 11:32 PM
Z06PSI's Avatar
Z06PSI
O.k. can someone give me a hand?
I have tried the relearn procedure (ignition 3 times, brake on, brake off, and ignition 3 more times leaving in run position) and the truck never honks or shows a message in the display. Were the Navis different then the Expys?
Old May 26, 2014 | 11:57 AM
alloro's Avatar
alloro
Do you have the key in the ON position when applying the brake?
1.Turn the ignition switch to the OFF position.
2.Turn the ignition switch from the OFF position to the RUN position three times, ending in the RUN position. Do not wait more than one minute between each key cycle.
3.Press and release the brake pedal.
4.Turn the ignition switch to the OFF position.
5.Turn the ignition switch from the OFF position to the RUN position three times, ending in the RUN position. Do not wait more than one minute between each key cycle.
6.The horn will sound once and the TPMS indicator will flash if train mode has been entered successfully. If equipped, the message center displays "TRAIN LF TIRE", place the magnet on the valve stem of the LF tire pressure sensor. The horn will sound briefly to indicate that the tire pressure sensor has been recognized by the TPMS module.
7.Within two minutes after the horn sounds, place the magnet on the valve stem of the RF tire pressure sensor.
NOTE: If the VSM (TPMS module integral to VSM) does not recognize any one of the four tire pressure sensors during the tire training procedure, the horn will sound twice and the message center (if equipped) will display "TIRE NOT TRAINED REPEAT" and the procedure must be repeated.
8.Repeat Step 7 for the RR and LR tires.
When the tire training procedure is complete, the horn will sound once and the message center (if equipped) will display "TIRE TRAINING MODE COMPLETE".
Todd Fuller
21
Oct 11, 2023 04:09 PM
ctfl
Apr 26, 2018 10:03 PM
bigfishford
75
Oct 11, 2017 04:48 PM
spudly98
Feb 17, 2010 11:44 AM
raudy
24
Mar 12, 2004 06:13 PM
