cmp ckp toggle yes and no sync
Old Sep 19, 2010 | 06:26 PM
Hardman's Avatar
Hardman
I should have mentioned I also put a new crankshaft sensor in at the same time
Old Sep 19, 2010 | 06:29 PM
cheezit's Avatar
cheezit
you could also try a new cam sensor. I really dont suggest tossing more parts at it however.
the issue can be comming from a bent or damaged tone ring as well. wich is why I suggst a lap scope. the issue is very rare but I have seen it.
by the way there are 2 sync pids.
one is sync and the other is ficm sync. is it one or both sync pids swiching?
Old Sep 19, 2010 | 06:34 PM
Hardman's Avatar
Hardman
The ficm sync goes to yes and does NOT toggle it stays on sync while engine running. Only the ckp cmp sync toggles , New harness, new ckp, new cmp, installed today
cheezit's Avatar
cheezit
maybe time to break down and go to the dealer.
Old Sep 19, 2010 | 06:43 PM
Hardman's Avatar
Hardman
I know it is but a person should be able to repair his/her own engine especially when they have access to the knowlegde on the internet such as the individuals on this forum. I have manage to fix the vehicles Ive owned and did not have access to such knowlegde as I do today. I am willing to pay to have my truck fixed but must exhaust all chances of a fix on my own or a least a good understanding of the vehicle I drive
Old Sep 19, 2010 | 06:46 PM
cheezit's Avatar
cheezit
I do respect that. trust me I do.
without the scope.... you can try a freq metere and see if you can catch one of the sensors droping out. I have not had luck with it though.
Old Sep 19, 2010 | 06:58 PM
adamtheman16's Avatar
adamtheman16
Do you mind if I ask what the actual symptom is? All I know is that the CMP and CKP are not syncing and you have replaced some parts. Is there a runnability problem and of what kind? When hot, cold, under load, RPM? I was just reading this thread and wondering what kind of symptom you are having?
Old Sep 19, 2010 | 07:34 PM
Hardman's Avatar
Hardman
I have another thread on the symtoms but the truck starts fine and does not smoke, after warm still does smoke until you touch the accelerator and then white smoke comes out timing goes to -12.00 btdc mass fuel doubles white smoke continues until you take the rpms up and smoke stops as timing goes to close to tdc and mass fuel desired drops back to normal if you go for a drive white smoke stops and the truck has lots of power . It is not an EGR problem coolant stays constant and oil stays constant
Old Sep 19, 2010 | 07:36 PM
Hardman's Avatar
Hardman
I dont know if the no yes toggle sync is related but it is very possible
Old Dec 13, 2010 | 08:57 PM
Dandy911's Avatar
Dandy911
What ended up being wrong? - I have the exact same issue.
Sync goes on and off. But the FICM Sync stays on while cranking.
I don't see any RPM at the tach when cranking.
Dave
Old Dec 13, 2010 | 11:51 PM
ciscofreak's Avatar
ciscofreak
Have this issue also.
Old Dec 14, 2010 | 12:23 PM
ciscofreak's Avatar
ciscofreak
Ok, I just checked my brother-in-law's 05 and it's doing the same exact thing. I know I have found some bugs in AE, maybe this is one of them?
My truck has dropouts at idle warm or cold. Little studders every couple of seconds.
Old Dec 15, 2010 | 12:05 PM
  #28
ciscofreak's Avatar
ciscofreak
Talked to AE about a possible bug with the ckp/cmp sync pid. They are looking in to it.
Would be easy to clarify if someone else with AE and a 6.0 could take a look to verify this.
Pikachu
Oct 18, 2016 07:06 AM
BDell82
Jun 21, 2016 08:00 PM
fixxxer-upper
Jan 3, 2012 07:19 PM
maxtegroom
Sep 19, 2011 10:46 AM
supperman2k
Aug 21, 2011 06:34 PM
