Ranger Climate Control
Old Sep 17, 2010 | 04:44 AM
Larryuidiot's Avatar
Larryuidiot
I have a 2000 Ranger xlt.Has the 4.0 in it.The **** that controls the heat and a/c I am having problems with.The a/c works in almost all positions.The only one it doesnt work on is the one to the floor only on the right side of the switch.The a/c should only work in the a/c position and the max a/c position.
I replaced the whole switch assembly with another one from another ranger.But it still lets the a/c come on in any positions.
Old Sep 17, 2010 | 07:27 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
Rangers are wired to have the A/C compressor run in all but the Vent position.
Old Sep 17, 2010 | 09:44 PM
Danger_Dave's Avatar
Danger_Dave
i think on mine that only position that the a/c doesnt apply to is the one where its the vent pointing at your face not your feet.
Old Sep 18, 2010 | 07:18 AM
tomw's Avatar
tomw
I think it may vary... My vehicles have the A/C engaged in full defrost, mixed defrost/heat, Max A/C, and the A/C position, going anti-clockwise around the dial. It is off in floor, off and vent positions.
If want full control, you can put a switch in the circuit to cut the power to the compressor clutch whenever you don't want to run the compressor. I've been tempted, but haven't gotten irked enough to do it.
tom
Old Sep 18, 2010 | 10:00 AM
g_k50's Avatar
g_k50
Service manual for 2001 and 1999 Ranger indicates that AC works in all positions except off and vent. Vent being one detent counterclockwise from off.
Old Oct 1, 2010 | 03:07 PM
pebeme's Avatar
pebeme
I am here to agree with all that say the AC works on all positions except off and vent (vent air will be hot) and I have played with this for a while and changed out the switch and all.
Old Oct 1, 2010 | 03:16 PM
grunt98444's Avatar
grunt98444
the ranger forum has how to info on how to change/control when the commpressor runs
I it has to do with splicing a switch into the wire that powers the clutch
Old Oct 4, 2010 | 07:25 PM
jimw411's Avatar
jimw411
my 2002 runs doesn't run the A/C in Off, Vent or The floor only position. It runs in all other positions: A/C, Max A/C, mix vent and floor, Def and def/floor.
Old Oct 4, 2010 | 07:53 PM
g_k50's Avatar
g_k50
Owner's Manual indicates proper operation of AC compressor and switch selection.
If variation is found from that indicated in owner's manual, have system inspected and operation corrected.
I wouldn't suggest changes not designed by SAE certified engineers, i.e., Ford engineered it right the first time.
Truckerswife
Jul 26, 2015 04:25 PM
rikfish
17
Jun 16, 2015 06:04 AM
JvV
Oct 23, 2011 08:44 AM
mbrown3039
Aerostar
Jul 2, 2009 01:09 AM
oshoguno
Jul 1, 2003 04:53 AM
