Please Help...
Old Sep 17, 2010 | 10:39 PM
cheezit's Avatar
cheezit
yup that's it. your other option is to moniter ebp and ebp voltage with a scan tool.
Old Sep 17, 2010 | 10:45 PM
Scottwoo's Avatar
Scottwoo
Great, thanks so much. I had a meeting with the owner of the dealership. He said they would go to bat for me with Ford. He also said to stay on the customer care and stay firm. He said their techs have numerous write ups talking about how cleaning the turbo does nothing. It's just Ford being cheap with the economy. He also let me into a couple of other options if all else fails...thanks again.
Old Oct 1, 2010 | 09:51 AM
Scottwoo's Avatar
Scottwoo
More woes with the 6.0...new turbo, new EGR valve, new VGT, new MAP sensor...still throwing codes:
P0069
P0107
P0299
P0470
Also, turbo still will not boost sometimes while driving. Exhaust gets noticeably louder when this happens also...?
Old Oct 1, 2010 | 09:56 AM
gearloose1's Avatar
gearloose1
Have you tried a computer reset / turbo relearn?
Why do I have a sneaking suspicion that the dealer tech that did the original turbo work skipped this step?
Do the reset, clear the codes...
Warm it up...
Reset it again (clear codes again if needs be)
Then activate relearn again
Then give it the exercise to relearn
Consider doing the air in oil purge routine as well..
Then see what happens.
Old Oct 1, 2010 | 10:00 AM
Scottwoo's Avatar
Scottwoo
I'm not sure...I'll ask. Bad thing is, I'm still getting the same problem with the turbo that I initially brought it in for.
Old Oct 1, 2010 | 10:04 AM
gearloose1's Avatar
gearloose1
Hey, there is warranty on the repair (Sept 1) that extends beyond the factory warranty.
Get that addressed first.
Note this:
https://www.ford-trucks.com/forums/9...o-problem.html
Do it.
Old Oct 1, 2010 | 10:19 AM
Scottwoo's Avatar
Scottwoo
Any insight on the warranty for the repair...I got nothing from Fords customer care and have been told I'm SOL on reimbursement.
Old Oct 1, 2010 | 12:22 PM
amgpro2's Avatar
amgpro2
Same thing happen to me but the truck was in the ford dealer shop when the warranty expired. They told me that because they only cleaned the turbo and did not actually replace it, the extended 1yr warranty on replaced parts did not cover the turbo. Call customer service and got the same run around. My turbo doesn't build boost under a very specific circumstance, while towing, after it shifts into over drive at around 60 mph. It doesn't happen all the time. I can also hear the exhaust go deeper and the truck lugs.
I starting to think it is not the turbo an maybe a sensor. No codes. I do have a high pressure leak but don't think the high pressure system affects the vgt controller unless it is leaking so much that is also affecting low pressure psi. I plan on posting my symptoms and solution once I figure mine out. First I plan on fixing high pressure oil leak and cleaning the turbo my self. If that does not work I will start with the EBP tube and sensor.
What should IPR, IPC, EBP be at 65mph?
Old Oct 1, 2010 | 12:40 PM
gearloose1's Avatar
gearloose1
Try the turbo relearn...computer reset..
Old Oct 1, 2010 | 12:57 PM
Scottwoo's Avatar
Scottwoo
Just got back from the dealer, got them to replace the EBP sensor and we also found frayed wires right at the electrical hookup on the VGT. Replaced the frayed wires and reset the codes. I talked about the computer reset and turbo relearn, but I believe they only cleared the codes with their laptop computer. After reading your other posts, I'm pretty sure they didn't do the master computer reset or the turbo relearn. According to what you've stated on how to do it, they didn't do any of that stuff. I'll keep my fingers crossed over the weekend. No codes on the way home, so if so I'll be back to do the master reset and turbo relearn. thanks for the info.
Old Oct 1, 2010 | 01:02 PM
gearloose1's Avatar
gearloose1
Hey, to be fair to your dealer, I am going to give them the benefit of the doubt if they put in a new EBP sensor and repaired frayed wires, they PROBABLY did the turbo relearn.
Note: the frayed wires SHOULD have been noticed on the last go around.
Unless they damaged it fresh!
But, no harm is done from doing a master reset --- did you see my new thread on that post?
Old Oct 1, 2010 | 01:11 PM
Scottwoo's Avatar
Scottwoo
I was standing right next to the tech as he did both so I know everything they did. When I pull up now, I go straight to the diesel area and the tech kinda gives me the what now. They have worked with me for the most part, besides sticking me with the bill. They have waived the labor for the last 3 visits...Big whoop after $2600 new turbo. Speaking of, I noticed the turbo they put on there was a remanufactured...any comments on that?? I thought I was getting a "new" turbo, but the cost was $1200 for the reman...Yes, I did read the new thread. I'll print it out and bring it to them if I have to make another trip.
Old Oct 1, 2010 | 01:15 PM
  #28
gearloose1's Avatar
gearloose1
Then... sigh...
Reman turbo--- be sure you got a WARRANTY on it.
Rickatic got burned (literally) by a bad turbo that put a blade into the combustion chamber.
Was the turbo from FORD?
Or joe's turbo fix me up shopper?
Or was it off ebay?
Did you see the original box? Keep it?
I would.
Old Oct 1, 2010 | 01:16 PM
  #29
bismic's Avatar
bismic
I gave you plenty of ammo to get re-imbursed for the turbo. As I said, the emissions wattanty is 5 yrs and 100k miles.
Old Oct 1, 2010 | 01:22 PM
  #30
gearloose1's Avatar
gearloose1
Master Mark,
Fella need a 2 X 4.
