Carb issues
Old Sep 16, 2010 | 05:28 PM
Broomfieldbum's Avatar
Broomfieldbum
Carb issues
I have some issues with my Carburetor, and I am hoping someone else here has more experience with them than I do. I think the Carb may be leaking also. It acts like it is running out of fuel all the time. I can get it to move but it is hard to get moving. I rebuilt the carb, but this is not exactly my cup of tea so I may have done something wrong. I really want to run my truck on E-85, but I have read that requires rejetting the carb. Any help would be appreciated. I have posted pictures so those who know these things can possibly if the carb. Look in my album
Old Sep 16, 2010 | 05:47 PM
66crawler's Avatar
66crawler
E85 takes almoast twice as much fuel. Carb problem sounds like a bad accelerator pump or maybe a floaty adjustment.
Old Sep 16, 2010 | 11:48 PM
Broomfieldbum
If it takes almost twice as much fuel then why does my 2010 F-150 get 16Mpg with gas, and 12 with E-85?
Old Sep 16, 2010 | 11:56 PM
arctic y block's Avatar
arctic y block
Guess i was asleep in class. What is E-85? Mind you I live in the bush deep in the rain forest so things come to us a whole lot later than down south stuff. We are still getting eggs from WW2.
Old Sep 17, 2010 | 12:00 AM
Broomfieldbum
E-85 is fuel that is 85% max ethanol. It is generally cheaper than gas, and since my 66' is just a tool around town truck I would like to make it something that supports Kansas, Iowa, and Nebraska more than Saudi Arabia. The first thing that most people warn you about running E-85 is that it dries gaskets out and so it will wear an old engine out or eat through fuel lines. I replaced all my fuel lines with new synthetics, and my engine is getting replaced next year anyway so, I figure start now. I just need to get the truck running well enough to tool around town in.
As it stands now it runs okay choked, and cold, once it warms up it runs horrible.
Old Sep 17, 2010 | 07:55 AM
Broomfieldbum
So, can anyone give me some instruction on how to adjust the float? I seem to remember I had similar issues with a 64 F-250 I had years ago. That one had fuel flowing out of the top though, and I replaced the float, problem solved.
If anyone could give me advice on how to change the float setting, I would appreciate it. I would also like to find the largest jet set for this carb so I can run E-85
Old Sep 17, 2010 | 08:32 AM
arctic y block
I would get a kit for the carb. The ones I have used come with a thing to adjust the float height. I don't know where to get bigger jets as I have always just drilled mine out.
Old Sep 17, 2010 | 08:36 AM
SixtySix Ford's Avatar
SixtySix Ford
I am local to you and could come over sometime and help you out with your problems. As for your question about E-85, I have no clue about what it takes to convert a gas engine to E-85.
Miera85
Oct 24, 2012 04:11 AM
hotfalcoon
Aug 6, 2012 08:14 PM
SlickWiSlick
Jan 12, 2010 06:29 PM
Greywolf
General Automotive Discussion
217
Jan 6, 2010 01:36 PM
nissandoc
56
Sep 28, 2009 07:04 PM
