carb id help
Old Oct 19, 2012 | 09:36 PM
Miera85's Avatar
Miera85
carb id help
does anyone happen to know what carb and model this is so i can get a rebuild kit. any help would be awesome. pistures should be in my gallery if you need some more
Old Oct 19, 2012 | 09:41 PM
Miera85's Avatar
Miera85
i thought i added pictures...
Old Oct 22, 2012 | 01:03 AM
wdfp's Avatar
wdfp
If its a holley it should have some numbers on the air horn front right facing the front of it. Its been a while since I saw one but it could be an economaster by Holley or not its just a guess from the pictures..
Old Oct 22, 2012 | 04:53 AM
EffoneHunded's Avatar
EffoneHunded
maybe a motorcraft 4300
Motorcraft 4300 Carburetor Repair Kit
good luck hope you figure it out
Old Oct 22, 2012 | 09:59 PM
wdfp's Avatar
wdfp
Now that I see the bottom it is not a holley, he's probably right with the 4300
Old Oct 22, 2012 | 10:47 PM
Miera85's Avatar
Miera85
Thanks. I have checked the whole thin over a million times. All I can find is a big number 2 and AA. The piece to adjust the lean on the side says Holley but I have no idea if that had anything to do with the rest of it. But like I said no numbers markings or stamps anywhere on it.
Old Oct 22, 2012 | 11:03 PM
dlburch's Avatar
dlburch
look on the front left side on the throttle plate...usually numbers are stamped there...behind the dashpot.
Old Oct 23, 2012 | 07:14 PM
Miera85's Avatar
Miera85
Alright i found it. The one spot i didnt hit with the toothbrush. its a motorcraft 4300 D2AF AA. kit was only $17.99. thanks for all of your help
Old Oct 24, 2012 | 04:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
ID number: D2AF-AA = Ford part number: D2AZ-9510-M .. 4V Auto-Lite/Motorcraft Carburetor (Motorcraft CA-788-A) / Obsolete
Original applications: 1972 Galaxie/LTD/Mercury Marquis 429 / 1972 Thunderbird/Lincoln/Continental Mark IV 460.
D2AZ-9A586-D .. 4V Auto-Lite/Motorcraft Carburetor Kit (Motorcraft CT-226-A).
Salty Dog
22
May 4, 2015 02:56 PM
BaltoMoJoe
Mar 23, 2015 01:50 PM
mse871859949
Dec 3, 2014 02:09 PM
urbex
May 11, 2012 07:07 PM
86 WV_F150
Dec 29, 2009 09:56 PM
