light switch pigtail
Old Sep 16, 2010 | 08:46 AM
kwheatcroft's Avatar
kwheatcroft
does anyone know if i can buy a new light switch connector? Or do i have to get a used one from a wrecking yard? I looked on Rockauto, but only found the new switch itself--no connector/pigtail available. I also noticed that the new switch does not come with the stem for the ****, i guess i have to re-use my old one?
thanks guys,
Kevin
Old Sep 16, 2010 | 02:54 PM
Lazy K's Avatar
Lazy K
Autozone should have it for around $15.00
Old Sep 16, 2010 | 04:09 PM
kwheatcroft
thanks, i'll check them out
Old Sep 16, 2010 | 11:36 PM
TexasGuy001's Avatar
TexasGuy001
If that doesn't work, NPD or LMC or maybe Ebay should have it.
Im guessing that your replacing it because it melted. If you want to avoid that issue and increase the output of your headlights a little, get a relay harness. Ebay and LMC have it.
Old Sep 17, 2010 | 09:04 AM
kwheatcroft
yes, it melted down alright. found both the switch and pigtail at autozone--$30 for both.
what harness are you talking about? A headlight relay harness?
Old Sep 19, 2010 | 07:27 PM
TexasGuy001
Yeah, it will take the load of the lights off of the switch, so it shouldn't overheat after that.
Old Sep 20, 2010 | 10:21 AM
kwheatcroft
thanks,
where can i buy one?
Old Sep 20, 2010 | 08:03 PM
TexasGuy001
The headlight relay setup should be available from LMC Truck. Its also on Ebay sometimes. What year is your truck? It should take either 9004 or 9007 bulbs. You'll need to figure that out before you buy a relay kit.
Old Sep 21, 2010 | 09:40 AM
kwheatcroft
its an 88'. I'll check out the headlights and go from there.
thanks for your help,
have a good one,
Kevin
Old Sep 21, 2010 | 10:00 AM
TexasGuy001
Your welcome. If you want better bulbs, upgrade to GE Nighthawk (not sport) or Sylvania Xtravison. They are a little brighter than the regular bulbs. Since you have an 88, it should be 9004 bulbs.
Old Sep 21, 2010 | 10:50 AM
hav24wheel's Avatar
hav24wheel
I made my own harness with relays for high and low, all plug and play after I was done for $25 all said and done....
Old Sep 24, 2010 | 06:17 PM
skyfox10's Avatar
skyfox10
So if you get a relay setup, the headlights will be brighter because you don't have the voltage loss from the current passing through all the extra wire to get to the cab & back?
Old Sep 25, 2010 | 07:00 AM
TexasGuy001
Thats true too. If you do that get some GE Nighthawk (not sport) or at least Sylvania Xtravisons bulbs. I have this setup and I can tell the difference.
Old Sep 25, 2010 | 10:39 AM
MEDF150's Avatar
MEDF150
Is there a relay kit that allows the Canadian daytime running lights?
Old Sep 26, 2010 | 03:13 AM
TexasGuy001
I have not seen anything about that before.
taxgod4u
2009 - 2014 F150
Mar 3, 2015 03:13 PM
Mercurypsycho
Aug 3, 2013 07:56 AM
jschluter
Nov 27, 2011 09:30 AM
barnbuoy
Dec 7, 2008 07:51 PM
frontco
Electrical Systems/Wiring
Nov 8, 2004 07:51 PM
