How to compression test?
Old Sep 15, 2010 | 08:50 PM
richdawg's Avatar
richdawg
Removed all 8 glow plugs and rocker arms on cyl 2 & 4 for easier access to connect tester. Connected tester and get no pressure to gauge when I turn it over. What am I doing wrong?
Old Sep 16, 2010 | 05:51 PM
richdawg's Avatar
richdawg
Anyone Know!!
Old Sep 16, 2010 | 06:14 PM
Cuda_jim's Avatar
Cuda_jim
I'll assume you have an adapter screwed into the GP hole. Remove the tester and place something over the hole, not your finger just in case there is pressure. If there is pressure then.......either the gauge is bad or you have a problem with that cylinder. Rings or valves.
TruckingBill
Sep 3, 2014 08:01 AM
nvrsadi
Jul 4, 2014 02:59 AM
Sidewinder2
Nov 12, 2008 11:43 AM
broncobillybob
1978 - 1996 Big Bronco
Feb 1, 2004 06:08 PM
sharlo
Jun 12, 2000 09:06 AM
