Fuel Pressure tester
Old Sep 2, 2014 | 08:55 PM
TruckingBill's Avatar
TruckingBill
I am looking to add a tool to my toolbox.
Will this fuel pressure tester gauge at Harbor Freight work on 6.0 L or is there a specific gauge I have to get?
Here the link - Fuel Pressure Tester & Fuel Injection Pump Tester
Bill
Old Sep 2, 2014 | 09:13 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
If you can't read it while you're driving it's kind of useless. Base fuel pressure at idle can be well up into the 50s and you'll see down into the 30s at WOT.
Old Sep 3, 2014 | 12:09 AM
Yahiko's Avatar
Yahiko
When doing just a basic test I use this one.
Engine Oil Pressure Test Kit
But texastech_diesel is right when it comes to driving.
Also you DO NOT want any fuel in the cab in case of a line
failure.
If you want to keep an eye one pressure as you drive you better off with electronic.
If you just testing it there is a post on what size orifice to use to simulate WOT.
Just use the search function at the top of the forum.
Sean
Old Sep 3, 2014 | 12:18 AM
Mr.Nobody's Avatar
Mr.Nobody
Does that kit have the proper bushing to screw the guage in? Or do you still have to buy that separate?
Old Sep 3, 2014 | 12:23 AM
Yahiko's Avatar
Yahiko
I think I got mine separately on Ebay. Not sure if it
comes with one or not. Also everything in that kit
is non O-ring.
Sean
Old Sep 3, 2014 | 05:03 AM
WatsonR's Avatar
WatsonR
Pressure in the 30s.... isn't that a problem?
Old Sep 3, 2014 | 06:20 AM
jsm180's Avatar
jsm180
I don't put too much faith in the HF gauges, I have found them to be very inaccurate. Replace the gauge with an accurate one or check the accuracy before each use.
Old Sep 3, 2014 | 07:56 AM
f350project's Avatar
f350project
Fuel Pressure
I believe if I'm not mistaken dynamic fuel pressure (driving pressure) shouldn't go below 40 PSI or you may start killing injectors due to starvation.
Old Sep 3, 2014 | 08:01 AM
mustang_309's Avatar
mustang_309
That is what he was getting at, just because your fuel pressure at idle in your driveway is at 50 PSI doesn't mean everything is ok, it needs to be tested under load at WOT.
You are correct except the number is anything less than 45 PSI can and will cause damage depending on how far below 45 it goes.
tr0y
Jun 24, 2016 12:41 PM
99StrokeXLT
27
Mar 23, 2013 09:34 PM
spooky01
Mar 2, 2012 04:46 PM
johnarahill
Jan 24, 2012 09:56 PM
