'96 300c.i.-6 PROBLEM
Old Sep 15, 2010 | 12:54 PM
expedite mike's Avatar
expedite mike
Looking for help....my '96 F-150 has a problem. When going down the road the engine just shuts off with out any warning. Will do the same occasionally when sitting at idle. It sometimes will restart immediately but sometimes will just crank and not fire up. When it is running it runs fine.
Any help out there will be appreciated.
Old Sep 15, 2010 | 01:26 PM
Zorfox's Avatar
Zorfox
Start off with the basics. Fire? Gas? Also check the codes if you have a reader. I may be wrong but on the '96 I think you need one.
I had a F150 that did the same. It ended up being a bad low pressure fuel pump. If you have dual tanks try the other, although I seriously doubt that is your problem.
IdrawPetPortraits
1983 - 2012 Ranger & B-Series
Mar 15, 2013 07:36 AM
300l6
Jan 6, 2011 07:13 PM
Butch(OH)
Apr 13, 2009 04:21 PM
emaxxdriver
Jun 29, 2005 07:55 AM
fender5
Sep 17, 2001 08:41 PM
