Transmission? Electrical?
Starts fine, runs fine until I stop.
When I stop, the engine idles oddly - it slows and speeds back up, tachometer and the battery gauges both lower just a bit and immediately return to normal. When the headlights are on, they dim in rhythm when the gauges dip. It does not do this in park or neutral.
Sometimes it does it right away. Sometimes it doesn't do this at all. Of course it did not do this when I took it to the shop. The battery is nearly new. Cables are fine. Alternator checked out ok.
Any help appreciated. Thanks!
Do you have a CEL lit, if so most autoparts stores will scan the engine computer for trouble codes, which can offer up good trouble shooting clues, so post All code Numbers.
Did the problem begin suddenly after some event & was it present before battery replacement????
EDIT: Seeing as how it doesn't do it in P or N, maybe suspect the torque converter is sticking/not unlocking. Does the OD light flash when it acts out??? If so, run this puppy by a trusted tranny shop to have them scan the tranny computer for trouble codes & post All numbers found.
Is the tranny fluid in good shape & has the tranny had regular scheduled maintanance filter & fluid changes over its lifetime with licensed fluids that meet or exceed Fords specifications???
The IAC is responsible for maintaining idle speed, so has it ever been removed for inspection, cleaned, or replaced???? More thoughts for consideration, with more feedback, maybe the Forum can make a more focused guess.
There's no warning lights coming on - no check engine light, no lit flashing OD warning.
I took it to Auto Zone for the engine computer scan and they said the 1996 Ranger doesn't have the plug to hook up to their scan system.
The problem started suddenly. The idle is fine when I first drive, the roughness starts after the truck has warmed up.
The battery was replaced a few months ago - long before the idle issue began.
The transmission fluid is reddish and doesn't smell burned. But the dip stick is corroded with red grit, and the fluid is gritty.
I inherited the truck. Dad didn't drive much, so I doubt that he had any maintenance done on it. It has 110,000 miles on it.
https://www.ford-trucks.com/forums/6...-pump-out.html
1996 was the first year of OBD-II requirements, I believe. Get out your owners manual and see if the diagnostic connector is mentioned. I also think that by law, the connector must be within 3 feet of the steering wheel. Look under the bottom edge of the instrument panel directly below the steering column for an open connector. Just sittin' there all pretty by itself...
tom
