1978 - 1996 Big Bronco
GOT A 86 Bronco
Old Sep 14, 2010 | 01:54 PM
toomanyf150s's Avatar
toomanyf150s
GOT A 86 Bronco
I got rid of a truck so wife said i coould get a new toy.Its a 86 bronco with a crap load x2 of wiring issues but hey thats why we have wiring diagrams.As soon as i am able to I will post picks and Start with the HELP me out info requests.New to the bronco section so hello evryone
Old Sep 14, 2010 | 04:05 PM
Encho's Avatar
Encho
The Southernmost Mod
Hey, welcome, post some pics of the new toy whenever you can .
Old Sep 14, 2010 | 04:36 PM
AbandonedBronco's Avatar
AbandonedBronco
Hey TooMany,
What engine's in that new beast?
Old Sep 14, 2010 | 05:35 PM
Matt8393's Avatar
Matt8393
Welcome, look forward to reading on your progress.
Old Sep 15, 2010 | 11:23 AM
toomanyf150s
It has a smallblock windsor of unknown size probably a 302 and auto tranny 6 in lift,4 in body lift sittin on 35x12.5x15.Fixed rear power window last nite and found the gas inside the truck smell.Makin a new filler hose today!
Old Sep 15, 2010 | 12:11 PM
Encho's Avatar
Encho
That Windsor mistery is easy to solve, look at the front of the engine, driver's side. If the waterpump mounts seem to make contact with the heads, it's a 302, if it's a couple inchs away, it's a 351. Being a 86, and supposing the tranny hasn't been swapped, you should have and AOD, as it was the most common tranny.
Old Sep 15, 2010 | 06:02 PM
greystreak92's Avatar
greystreak92
Welcome to the Big Bronco Forum... best of luck with the new truck. Keep us posted.
Old Sep 16, 2010 | 06:38 AM
toomanyf150s
Fuel filler hose Replaced.Now the messed up wiring.Someone refresh my memory 86 was a carb. Not fuel injected right? The 86 wiring diagram in the old haynes book found under the back seat shows fuel injec. wiring.Mine has a edelbrock performer intake and edebrlock carb on it and a old school 60's dizzy,no duraspark HMMMMMMMMMMMMM Where to start,at least all the lights work if you flip a toggle switch Frickin everything has been run to a relay off thay toggle.I guess previous owner bad a battery draining prob?
Old Sep 16, 2010 | 07:54 PM
greystreak92
86 was a transition year. You could have either a carb or EFI depending upon when it was made and where it was sold. EFI engines are easy to spot by the long intake air hoses to the throttle body and the rather hefty upper intake with the displacement in liters embossed in the top of it.
bornreadyredneck
15
Nov 26, 2009 10:55 AM
devinshaw
Jan 4, 2008 06:25 PM
johnhed
Mar 20, 2004 07:38 PM
