1978 - 1996 Big Bronco
86 bronco
Old Nov 10, 2009 | 08:57 PM
bornreadyredneck's Avatar
bornreadyredneck
86 bronco
i changed my motor form a 90 f150 to my 86 bronco 5.0 changed wire harness to match truck to motor motor races when ide air controle is plugged in what would do that ?
Old Nov 10, 2009 | 09:56 PM
Aciancio's Avatar
Aciancio
what motor did the bronco have before, did you change the computer?
Old Nov 10, 2009 | 10:03 PM
greystreak92's Avatar
greystreak92
Constant open IAC or an issue with the circuit that controls it. Have you pulled codes to see if you are getting any IAC-related fault codes? Make certain you have no open vacuum barbs on the throttle body itself. If the IAC is dirty, the valve can stick open. You can clean it with throttle body cleaner that is safe for catalytic converters and coated throttle bodies. Make certain to keep any liquid out of the electronic end of the IAC.
Old Nov 11, 2009 | 10:50 AM
Kemicalburns's Avatar
Kemicalburns
unless your running the90 ecu your not going to operate properly. the 86 harness and computer should have been used on the 90 motor. no reason to change that.
Old Nov 11, 2009 | 08:25 PM
bornreadyredneck
86 bronco
i had to change the harness because the person who took the motor out cut the wires so i got a new wire haness and i also changed the iac
Old Nov 11, 2009 | 08:27 PM
bornreadyredneck
the truck used to have the same kind of motor in it
it had a efi 5.0 same as i put in and no check engin light so dont think it is throwing a code
Old Nov 11, 2009 | 08:58 PM
bornreadyredneck
i was told the tps would screw up the iac
Old Nov 11, 2009 | 10:53 PM
greystreak92
Kem,
Jog my memory, why would it be necessary to run the 86 harness? What changed between 86 and 90 that necessitates this? Just curious. I do understand keeping the harness and PCM matched but I want to understand what the differences are that make it necessary.
Old Nov 12, 2009 | 11:51 AM
Kemicalburns
the efi harness for 85-86 where wired differently. they changed in 87 so the pinouts would be different and certain things wont be talking.
www.fordfuelinjection.com.
you need to either run the 90 harness and 90 ecu or get an 85-86 harness to work with your current ecu.
Old Nov 13, 2009 | 12:22 AM
greystreak92
Cool, thanks.
Old Nov 18, 2009 | 11:07 PM
bornreadyredneck
i changed the harness and pcm because the wiring and conectors and locaton of pcm where diffrent
Old Nov 19, 2009 | 10:27 AM
Kemicalburns
ok so you are using the 90 harness and computer then? please be more clear
Old Nov 24, 2009 | 11:25 PM
bornreadyredneck
no im using the 86 harness and computer the 90 haness and computer set up is diffrent from the 86
Old Nov 25, 2009 | 10:37 AM
Kemicalburns
so i dont understand what you changed then. because the sensors are all in the same places on either motor. so in other words you should be able to take any efi 5.0 from 85-91 and drop it in and connect up your 86 harness and run your 86 ecu with no problems.
can you tell us what exactly you changed on your harness?
Old Nov 26, 2009 | 10:53 AM
bornreadyredneck
yes but for some reason the truck races at 3000 rpms and i changed the tps sensor and the aic
