Another dreaded fuel sender question...
Old Sep 14, 2010 | 07:43 AM
Bueller's Avatar
Bueller
Searched, and figured my gauge problem was most likely in the tank. Dropped the tank, removed sender, and took it apart to see what was going on. It looked like the arm wasn't contacting the windings (seen it before on other stuff), so I 'tweaked' it back a bit, and made sure it still had some tension. Wife was at work with my ohm meter in the trunk, so I plugged the sender in, and checked the gauge at several positions. All seemed good. Reinstalled everything, and put the 5 gallons it had in back. Gauge only came up to empty, which is why I was taking it apart in the first place. I'm thinking I just need to add a bit more gas, but in case that doesn't work....
What aftermarket fuel senders have you guys had good luck with? I seen a couple of bad reports on bronco graveyard...I don't really know if Ford still sells the factory one for my '84, but I really don't want to spend that kind of money anyways (especially since I'm broke as a joke all the time)...
Frank
Old Sep 14, 2010 | 08:17 AM
smashclash's Avatar
smashclash
I bought mine online from Advance Auto. It's a spectra brand and has worked fine. Use coupon code LC123 and you're good to go.
Old Sep 14, 2010 | 07:14 PM
Eddiec1564's Avatar
Eddiec1564
Check the brass float on the sending unit. They fill up with gas and will sink causing the empty reading.
cchvacman
Aug 10, 2014 03:30 PM
SuperDuty93
Sep 30, 2013 09:50 PM
chrisginco
Jan 13, 2012 04:59 AM
3spd
Sep 17, 2010 05:25 PM
tip49
Jul 13, 2010 09:39 PM
