code 1405
Old Sep 13, 2010 | 11:36 AM
socal00's Avatar
socal00
code 1405
Went today to have a noise check on my 00 expedition and my check engine light was on so had them just check out what the code was. It a 1405 code i think egr code. Instead of paying the steralership to fix it, is this something easy I can fix? or better off taking it back to get fixed?
Old Sep 13, 2010 | 12:35 PM
socal00's Avatar
socal00
i searched a little bit and found it might be a cracked, clogged or disconnected hose. does anyone have a pic where its at. 2000 expedition 5.4
Old Sep 14, 2010 | 08:17 PM
Moto Mel's Avatar
Moto Mel
The EGR valve is located on the back side of the intake manifold on my Navigator and the pipe that feeds it is in the driver side exhaust manifold. there is a smaller pipe that goes to the actual sensor that would be mounted on the engine or firewall. The Navigator and Expedition systems are similar but the components may be located in different locations. Check the large stainless pipe for cracks or breaks and the smaller for a burnt or broken hose(s), the Nav has 2 small hoses and I don't know what the Expy has.
Old Sep 24, 2010 | 07:45 PM
socal00's Avatar
socal00
can someone post a pic of what it looks like?
Old Sep 24, 2010 | 07:55 PM
socal00's Avatar
socal00
I think I found it the hose says gas/fuel. I checked it and theres no cracks, but i ran my finger across it and all the writing on it was flaking off of it. not sure where else to look. any suggestions?
Old Sep 24, 2010 | 09:37 PM
socal00's Avatar
socal00
found the problem
now i need to clear the engine light
Old Sep 24, 2010 | 11:19 PM
Spinner_89's Avatar
Spinner_89
Where in the engine compartment did you find the broken hose?
Old Sep 24, 2010 | 11:47 PM
Moto Mel's Avatar
Moto Mel
Originally Posted by socal00
found the problem
Glad you found the problem.
Just disconnect the battery for a few minutes and reconnect, the light should then be off.
Old Oct 5, 2010 | 12:52 PM
socal00's Avatar
socal00
on the right side of the throttle body. you have to take that plastic cover off that sits on top of the throttle body
Old Oct 5, 2010 | 02:09 PM
Moto Mel's Avatar
Moto Mel
Good info and pics. Now we have one more place to check for vacuum leaks, it just keeps getting better and better.
strikechords
Escape & Escape Hybrid
Sep 19, 2013 10:20 PM
Plowboy34
1983 - 2012 Ranger & B-Series
Jul 22, 2012 01:40 PM
pos2nat
May 11, 2007 11:01 AM
DeanG
1997 - 2003 F150
Mar 24, 2006 02:33 PM
997.3PSD
Jul 29, 2005 09:39 AM
