Sponsored by: Real Truck
5er towing w/ E450
Old Sep 13, 2010 | 09:17 AM
gypsyblood's Avatar
gypsyblood
5er towing w/ E450
i am looking at a 2006 E450 duelly w/ the v10 engine . it has a flat bed conversion it. i want to tow a 14.5k 5er ? finding specs on this can be difficult? thanx for any help.
Old Sep 13, 2010 | 10:26 AM
bunklash's Avatar
bunklash
Just guessing here, but you may not find published specs because E series aren't set up to handle 5ers. Still guessing...if the frame, suspension, wheels, tires, etc. are the same as the F450, it should handle that weight 5er with no problem.
BTW, welcome to the forum, it's THE PLACE to go for good info and helpful members.
Old Sep 13, 2010 | 10:35 AM
peteyx's Avatar
peteyx
Was the van body removed? I am towing (quite well) a 14k fifth wheel with my '06 F250 PSD SRW.
Old Sep 13, 2010 | 10:38 AM
gypsyblood's Avatar
gypsyblood
thank you, it seems to be a cutaway e450 with a extra room behind seats and windows. so i looked on trailer life tow guide under extended cab or supercab truck chassis cab and came up with 18,000# 5er towing i beleive the gearing 4:56 . just wondering now if this is a good comparsion? truck chassis cab= van chassis. sounds like it easly tow my trailer. i have read on e-net that the van v-10 are a lil'less HP/TQ than the trucks becuase of exhaust and intake restrictions, dont know how true it is ? thanks again.
Old Sep 13, 2010 | 10:49 AM
bpounds's Avatar
bpounds
I don't think you will have power, braking, or weight issues. But how long is this flat bed conversion? You need your pin to be about 50" behind the cab, and your pin also needs to be at least directly over your axle and preferrably 2-4" in front of your axle. If your pin is too far forward, your trailer will hit the cab in a sharp corner, and if your pin is too far rearward your handling will suffer. A slider hitch might work, but a gooseneck might also work best with a flat bed. Since we don't know what you are working with, I recommend you work with an RV dealership service department to get this set up safely.
Old Sep 13, 2010 | 10:56 AM
redford's Avatar
redford
FTE Leadership Emeritus
What transmission? You may be handicapped a little, as I think the E-series didn't get the 5R110W, but kept the 4R100 transmission.
Old Sep 13, 2010 | 11:38 AM
gypsyblood's Avatar
gypsyblood
i will need to find out on the tranny. and right now it has a nice diamond plate flat bed w/ a gooseneck hitch so i believe its a reg. size bed. 5er should work? will heft to take a couple measurment fer sure. thank ya!
Old Sep 13, 2010 | 11:43 AM
bpounds's Avatar
bpounds
If you've already got a gooseneck ball, I would look at an adapter for the trailer to make it a gooseneck.
Old Sep 13, 2010 | 11:45 AM
gypsyblood's Avatar
gypsyblood
nay, would rather run my trailersaver air ride hitch
Old Sep 13, 2010 | 12:21 PM
gypsyblood's Avatar
gypsyblood
but that would be great idea to save some time an trouble
Old Sep 13, 2010 | 12:34 PM
bpounds's Avatar
bpounds
I think you can get a air ride gooseneck adapter, IIRC. Anyway, something to consider.
Old Sep 13, 2010 | 12:52 PM
gypsyblood's Avatar
gypsyblood
yea, thats why i,m here. thank you like to hear all ideas!
Old Sep 13, 2010 | 07:44 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The last year the 4R100 was in anything was 2004. This 2006 is a TorqShift five speed, also known as the 5R110.
Old Sep 13, 2010 | 08:07 PM
redford's Avatar
redford
I stand corrected. I thought the E-series didn't get the 5R110W. Thanks Mark.
Old Sep 13, 2010 | 08:30 PM
gypsyblood's Avatar
gypsyblood
so the 5R110W is the "good" trans ? that i would want for towing ? hard to believe more than 10years ago i was a ford tech!
