Aerostar Ford Aerostar
Van Went Dead
Old Sep 12, 2010 | 10:17 AM
bsr2002's Avatar
bsr2002
Van Went Dead
I was leaving the resteraunt, I started the van. It idled for a few seconds then turned off. Everything turned off radio, lights everything. Now it won't start at all! I tried to jump it but didn't work. Any Ideas?
Old Sep 12, 2010 | 12:15 PM
DMTR's Avatar
DMTR
Sounds like a bad connection upstream. Check the battery terminals. Check the negative cable's connection to the body and the positive cable's connection to the starter relay. If you have absolutely no lights, radio, etc even when the jumper battery is connected then it must be the negativ cable. Disconnect it from the body (if it still attached) clean and reconnect it.
Old Sep 12, 2010 | 12:33 PM
DMTR's Avatar
DMTR
Old Sep 12, 2010 | 04:03 PM
bsr2002's Avatar
bsr2002
Turned out to be bad solenoid off the firewall, WTH?!? I just got the old one less than 2 months ago. Do these things go bad often?
Old Sep 12, 2010 | 10:00 PM
DMTR's Avatar
DMTR
With a broken starter relay you can't start the engine but you would still have power to lights, radio etc and it would not shut down the engine if its already running.
I guess I misunderstood something but I am glad that it is all right now.
Speaking for myself, I have never had troubles with that relay.
Old Sep 13, 2010 | 12:51 PM
bsr2002's Avatar
bsr2002
No you didnt misunderstand...I did say all the power went off. Maybe it was coincidental that the van started up? Maybe some wires crossed? I was just happy when it started up...lolz!
Old Sep 13, 2010 | 04:33 PM
xlt4wd90's Avatar
xlt4wd90
Sometimes the nuts on the terminal that all those wires are attached to on the starter relay loosen up. That in itself will cause intermittent problems, but it can arc between connectors and cause increases in resistance, like accumulating corrosion or dirt. It can not show up for a long time, and suddenly, you got no power. So that's one place I would check.
Old Sep 13, 2010 | 10:07 PM
DMTR's Avatar
DMTR
I agree. Check that connection. My friend's Caravan got stuck right at a drive through window because that freakin' relay. But it wasn't even the relay itself just the connection on the relay.
Rico47635
48
Dec 15, 2012 07:26 PM
themred65
Aug 10, 2010 04:14 AM
stevevan
Apr 16, 2006 08:24 AM
Jerry Blair
Aug 25, 2003 08:53 AM
SOGsnakebite
Feb 14, 2003 12:47 PM
