remote entry not working
Old Sep 11, 2010 | 11:27 PM
xc4jokestomper's Avatar
xc4jokestomper
my 95 f150's remote isnt working.. i tested the battery at the little thing they have at autozone and it says the batteries fine. the power locks work fine when i use the buttons on the doors but when i use the little remote i get nothing. no clicking sounds or anything. what should i be looking for?
Old Sep 12, 2010 | 12:19 AM
skyfox10's Avatar
skyfox10
is this a stock ford unit that came on the truck or is it aftermarket? I would run through the process of programming the remote to the truck. I know it's easy on my 00 mountaineer, but I've never had to do it on my gen 9 trucks that came with factory remote lock/unlock.
Old Sep 12, 2010 | 08:16 AM
xc4jokestomper
its the stock ford unit that came with it.
how would i go about programming it to my truck?
Old Sep 12, 2010 | 11:24 PM
TexasGuy001's Avatar
TexasGuy001
Maybe the key fob has a dead battery. Autozone usually has a battery tester where you push the button and it tells you if you remote works.
Old Sep 13, 2010 | 05:20 AM
xc4jokestomper
i tried it at autozone and it said it was working.
Old Sep 13, 2010 | 05:58 AM
TexasGuy001
Sorry I didn't thoroughly read your post. Maybe the main unit is not properly connected.
Old Sep 13, 2010 | 10:20 AM
skyfox10's Avatar
skyfox10
Reprogram Keyless Entry Remotes
Old Sep 13, 2010 | 12:39 PM
redlightning93's Avatar
redlightning93
Originally Posted by skyfox10
This procedure will not work on your '95 truck.
Here is the correct Programming Procedure for your truck:
Section 01-14B: Door Lock Control System, Electronic 1995 Bronco/F-Series Workshop Manual
DESCRIPTION AND OPERATION
Transmitter Programming
NOTE: The remote entry features will not function when the ignition switch (11572) is in the RUN or ACCESSORY position.
To unlock the driver's door, press the UNLOCK button on the transmitter (which is programmed into the remote entry receiver module) once. This will also disarm the anti-theft system, if equipped.
To unlock all doors, press the UNLOCK button on the transmitter twice, the second depression must be within five seconds of the first UNLOCK depression.
If more than five seconds have elapsed since the first depression of the UNLOCK button, pressing the UNLOCK button again will only unlock the driver's door.
To turn on interior lamps (13776), press either UNLOCK or PANIC.
To lock all doors, press LOCK button on the transmitter once. This will also arm the anti-theft system, if equipped.
To confirm that doors have locked, press LOCK button again, within five seconds of the first depression. This will beep the horn (13832), flash the parking lamps and lock all doors again.
To activate the personal security alarm, press the red PANIC button. The horn will beep and parking lamps (13201) will flash for a maximum of two minutes, forty-five seconds.
To deactivate the personal security alarm, press the red PANIC button again or turn the ignition switch ON.
NOTE: The remote entry receiver module erases all previous transmitters from memory when the transmitters are programmed or re-programmed. The remote entry receiver module can store up to four transmitters in memory.
To program (or re-program) transmitter(s) into the remote entry receiver module, perform the following steps:
Turn ignition switch to ON or ON/ACCESSORY position and momentarily short the two terminals of the Program Connector (C4) (a two-pin connector taped to the wire assembly connected to the remote entry receiver module, approximately 6 inches from the remote entry receiver module). All doors should lock then unlock. Remove shorting pin.
Press any button on transmitter. All doors should lock then unlock to verify the transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same transmitter). If door locks still fail to respond, go to Pinpoint Test F.
Repeat Step 2 to program additional transmitters into the remote entry receiver module (up to four transmitters maximum).
Turn ignition switch off. All doors should lock then unlock.
Check operation.
Old Nov 28, 2010 | 03:46 PM
xc4jokestomper
what could i use to short the two connectors? would a paper clip work?
Old Nov 28, 2010 | 03:56 PM
redlightning93
A paper clip will work, just make sure it does not short against any metal in the truck.
Old Nov 28, 2010 | 04:21 PM
xc4jokestomper
I got it working! Thanks guys. I dnt know what i would without u all lol
Buck 1
2004 - 2008 F150
Jan 21, 2014 07:19 PM
ExpySport
Oct 22, 2008 07:40 PM
Jzinkiewicz
Electrical Systems/Wiring
Dec 29, 2007 10:08 AM
thornious
Feb 19, 2003 05:37 PM
