Problems with Recon White lightning LED bar
Old Sep 11, 2010 | 06:44 PM
Crawgator's Avatar
Crawgator
Unhappy Problems with Recon White lightning LED bar
Hello all,
I am installing on a 2010 F150.
I am on my second led bar. Manufacturer sent another under warranty. I am trying to install and am wondering if I have the wiring wrong. I am taping into the wires on the 7 pin trailer harness. Yellow-Left, Green-Right, Brown-Running light, Silver with Brown strip- Reverse.
Everything works until I turn my headlights on. The bar gets erratic. Either turn signal and the correct side will flash but the rest of the LED's flicker. If I hit the brakes the entire bar flickers.
I have spliced female spade connectors into the harness and male onto the bar wires. All connections are soldered.
Any ideas? Do I have the right wires? Only one in question is the running light. Is it the brown wire? Has anyone installed on a 2010 model? Was there a change to 2010 models?
This should be simple but I have struck out.
Old Sep 11, 2010 | 06:56 PM
Franklin2's Avatar
Franklin2
First thing I would check is the ground. I would read the instructions, and if the bar itself is metal, and is a ground for the lighting, then run a wire from the metal part of the bar down with the other wires and bolt it to the frame or some other good ground on the truck.
Old Sep 11, 2010 | 07:45 PM
Crawgator's Avatar
Crawgator
Dave,
Light Bar is plastic and I have it grounded to the frame. I have read the instructions several times. Not the best in the world. Even checked the website for updated instructions. Standard 4 pin wire hookup from the bar to the flat 4 connector on the truck or you can hardwire it. I am wondering if I have the right wire for the running/park light.
cchsbuzz19
Electrical Systems/Wiring
Jan 19, 2015 04:18 PM
justdoinbizbp
Feb 16, 2014 06:04 PM
ihbond
Dec 28, 2013 11:33 PM
FordIowan
Dec 25, 2013 03:45 AM
mohican
All Things Towing
May 26, 2009 04:52 PM
