Any one know if ford used the same dash wiring harness for the gas and the diesel. I am putting a 95 f150 body onto a 91 f250 frame and need to find out if i need to hunt up a new wiring harness.
The wiring is different. What I don't know is if the main harness is made different, or the it's the same and the diesel part is a add-on harness.
What comes to mind right away is the glowplug system and the "wait to start" system in the dash.
It depends though on your intended final results. If you are going to wire a manual glowplug system on the truck, you would not need that wiring, but just add a few of your own wires.
