Sponsored by: Real Truck
GPS hookup
Old Sep 11, 2010 | 02:07 PM
pedz's Avatar
pedz
4wd Low
GPS hookup
I found one thread with suggestion on how to hook up a GPS. I want the power to be switched. The reply was to just splice into a switched power. But how do I find that?
I have a 2000 F250 Diesel 4x4 "super cab" (I call it an extended cab).
The books says that fuse 27 is available but I don't see how to get to the output of it.
Thanks
Perry
Old Sep 11, 2010 | 05:09 PM
Kajtek1's Avatar
Kajtek1
Finding switchable power in Ford is tricky. Even CC nd wiper motors are not switchable.
I would go to the fuse panel under the steering wheel and test the fuses, than you can use spade connector to tap there. GPS takes minimal current, so very small wire is required.
Old Sep 11, 2010 | 05:18 PM
pedz's Avatar
pedz
4wd Low
Oh. I think I see. "use spade connector to tap" -- so just remove the fuse and tap in to the side that has the power. Is that what you mean?
I was trying to figure out how to tape in after the fuse. Fuse 27 in my case sounds perfect but trying to figure out a good approach to tap into it.
Thanks again,
Perry
Old Sep 11, 2010 | 06:22 PM
Grumpy Moose's Avatar
Grumpy Moose
This is actually very simple. Ford provides an extra +12V switched wire for this very purpose. Do you know where your customer access wires are? In your truck there are 4 unused wires (red, blue, white, black) that run from the engine compartment (on the right side near the master cylinder) through the firewall and terminate behind the fuse access panel above the OBDC connector. They are provided for whatever purpose the owner needs. On the inside, there is also a spare +12V switch wire provided as well. On my truck it is light blue with a yellow stripe. Just splice into that and you are good to go. Do a search on "customer access" to read more.
For example:
https://www.ford-trucks.com/forums/5...hed-power.html
Old Sep 11, 2010 | 07:28 PM
pedz's Avatar
pedz
4wd Low
For example:
I found the white, black, red, and blue wires on both sides of the firewall. That isn't exactly what I was hoping for -- since they are just wires without any power connecting to them.
In the same bundle on the inside is a wire that is blue with a red stripe -- its smaller. It appears, based upon my ohm meter to be hooked to fuse 27 but when I turn on the power, it is not getting any power (but the fuse is).
So... I'm still looking for a wire that is switched.
Thanks,
Perry
Old Sep 11, 2010 | 08:23 PM
pbeering's Avatar
pbeering
Go to a parts store, Meijer, Walmart, etc and buy a piggy back fuse holder. It comes with an assortment of fuses and plugs into an existing fuse in the fuse block giving you power and preserving the fuses.
Old Sep 11, 2010 | 09:20 PM
Grumpy Moose
Thanks,
Perry
Look further down by the OBDC connector, there should still be one more free wire. I found a wire similar to what you are describing in my truck too - I still haven't figured out what it is for. But there also was a separate +12V switched wire as well. I hooked my CB up to it and it works like a charm.
Old Sep 11, 2010 | 10:47 PM
dchamberlain's Avatar
dchamberlain
Find the OBD-II connector to the right of the driver. Follow the wiring loom for it up under the dash. You should find a single, blunt cut wire coming out of the loom and taped to it.
It's switched with a 10 amp fuse.
Old Sep 12, 2010 | 05:40 PM
pedz's Avatar
pedz
4wd Low
Here is the end of the weekend update -- to be continued next weekend.
First, my battery is having problems. I put it on a charger. My tests today are different from yesterday which is why I mention it at all.
My VIN is 1FTNX21F9YEA27566 (to be exact).
On my truck, I have a group of 5 wires with a wrapper of "Customer Access". The blue, black, red, and white (as described) just go to the other side of the firewall. My guess is these are 14 gauge wires. The 5th is a 16 gauge wire which is blue (perhaps light blue) with a red stripe. It DOES go to fuse 27. I got the engine started and it had power. Pulled the fuse -- no power.
PLUS... as a few mentioned, if you start at the ODB-II connector and go up, there is a cut off wire. 16 gauge. It is blue (or light blue) with yellow. This (today) seems to be just a signal from somewhere.
I didn't hook up the GPS. I'm packing for a trip and I'll try and attack this perhaps Thursday before I leave or I may just wait until I get back. Right now, I have just the ugly GPS cable across the dash and down to the cigarette lighter.
Thank you all... your descriptions are awesome!
Perry
Old Sep 12, 2010 | 06:58 PM
rjmay's Avatar
rjmay
Be careful that the GPS is not 5 VDC instead of 12V.
