Sponsored by: Real Truck
Engine just threw up a spark plug.
Old Sep 9, 2010 | 11:24 PM
djpahan's Avatar
djpahan
I have had this noise that bothered me for couple days. Then today, when I was getting ready to leave local store, started the engine and boom, a loud flapping noise from the engine. (luckily I just drove for 3 hrs from the ocean shore). I open the hood and find spark plug with rubber peace and spring on the top of the engine. I've located ignition coil without mounting ear on the top of the exhaust. After the trip to the Schucks, I have installed new Spark Plug and New Coil. (I was told at the store that most likely I have a striped thread and need to order thread repair kit.) My dad told me that with me hearing noise for couple days most likely spark plug got loose (remember I bought truck just over month ago), and I may be lucky that my thread might be OK. I have installed new product, (had to finish another job) almost 50 miles and seems to be OK.
Now this weekend I would like to have new plugs installed and check make sure that everything is OK.
any thoughts
Old Sep 10, 2010 | 12:20 AM
Hybris's Avatar
Hybris
I would check to see that all the plugs are properly torqued as too much tends to make a "ping" sound followed not too long after by a plug blow out. I don't know about using a thread repair kit on something that takes the pressures that a spark plug sees during use.
Better to replace the heads in my opinion.
Old Sep 10, 2010 | 06:31 AM
1975StroppeBaja's Avatar
1975StroppeBaja
Definitely no need to replace the head. Thread repair kits (helicoils) are the recommended way to fix the head after this happens.
Do a search here for lots of info on the subject. Or, do a google search for "triton spark plug repair kit" and you'll find dozens of places that sell the kit.
Time sert is a popular one....
++ TIME-SERT FORD SPARK PLUG REPAIR, blown out spark plugs problems blowout Frequently Asked Questions ++
Good luck!
Old Sep 10, 2010 | 09:35 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Actually, calling them "helicoils" is a misnomber. The Heli-Coil® brand doesn't make a good insert for these heads as far as I know.
But you are right in that Timesert® does make the correct kit. It can be done with the head on the vehicle, and stays put when done right.
Ford also has a kit available.
Old Sep 10, 2010 | 09:50 AM
bakon's Avatar
bakon
What year truck? Was common in the first couple years.
Old Sep 10, 2010 | 11:08 AM
exiled's Avatar
exiled
Man that sucks. Did the engine not have a miss? or do you think you wasn't driving it with the plug out?
Old Sep 10, 2010 | 11:16 AM
1975StroppeBaja
Ah yes... I was using that term as the type of part instead of the company that makes them. Kinda like the term "posi-traction". That's a GM thing but alot of folks use it to describe any limited slip diff.
dkf's Avatar
dkf
If you are not able to do the work yourself call around to shops and ask them about the repair. If you get an answer that has the word "HeliCoil" in it cross them off the list. A helicoil is not the proper fix. I would repair the damaged hole with a Timesert kit as suggested in prior posts. The inserts from Timesert are actually flared with the tool in the kit at the bottom so they do not back out and come loose. There are some Timesert kits for the 2V 4.6l, 5.4l and 6.8l on Ebay.
As for the plugs make sure they put on OE replacements from Motorcraft or Autolite.
Old Sep 10, 2010 | 11:59 AM
Hybris's Avatar
Hybris
Good luck!
Thanks I didn't know that they made good kits for this sort of thing.
Old Sep 10, 2010 | 12:31 PM
89CrewCab's Avatar
89CrewCab
Checkout these guys: Blownoutsparkplug.com
Old Sep 10, 2010 | 02:09 PM
djpahan's Avatar
djpahan
Thanks, guys. I have 99 v10. I've driven to work today with new plug and seemms to be ok. I will defenetaly check al of htem this weekend.
Thanks adain for all the help
Old Sep 10, 2010 | 07:47 PM
Fordfanatic4life's Avatar
Fordfanatic4life
make sure you check and set the torque properly on ALL ur plugs and then check em again in a month or so..
look for ANY that show signs of loosening..
Old Sep 10, 2010 | 09:42 PM
EXv10's Avatar
EXv10
This is exactly why you have to pay attention to a ticking/exhaust leak type noise and act fast when you hear it. I always keep my ears tuned for that noise now that I am aware of the problem.
Old Sep 12, 2010 | 05:08 PM
djpahan's Avatar
djpahan
you have hit it right on the nail. I have heard that leak ever since I bought it. If I would mention it to someone, they would tell me that I got used to new car - no engine sound (I had 06 Chevy cargo van, bought it brand new, totaled it in April). Small tune up was on my budget for next month, unfortunately I had to do it earlier, but man, I just love the way this engine sounds now: no leaks, no weard sounds.
Thank you guys, thank you for your quick respond and great input.
This site rocks.
PS. Couple of plugs had white residue on them. Any ideas?
Old Sep 12, 2010 | 05:27 PM
redford's Avatar
redford
Anti seize compound perhaps?
