strange thumping noise
Old Sep 11, 2010 | 01:21 PM
octaneforce's Avatar
octaneforce
while accellerating quickly from a stop, my truck makes a fast thumping noise. it almost sounds like my abs is kicking in. not very loud, but it seems to be worse while accellerating through a turn. motor mounts, tranny mount, u joints, and brakes are all new. the rear end was also just completely rebuilt. the rear shocks are also pretty new. the truck is a 92 f150 4.9l 2wd 5spd. all ideas are appreciated.
Old Sep 11, 2010 | 03:11 PM
White 97 xlt's Avatar
White 97 xlt
If it has a 2 piece driveshaft, take a look at the center carrier bearing..
Old Sep 11, 2010 | 03:26 PM
Slip ford man's Avatar
Slip ford man
How's the exhaust system look to you, look to see if there are any rubbing marks on the drive shaft from muffler sway in a turn
Old Sep 11, 2010 | 10:55 PM
octaneforce
the driveshaft is a one peice and there are no rub marks. the exhaust is also brand new and its very sturdy.
Old Sep 12, 2010 | 02:51 PM
White 97 xlt
How are your spark plug wires? I'm wondering if it might be an engine miss under a severe load condition.. I had a set of wires go bad an one of my "birds" once, it ran perfect until I really loaded it up, then it missed and caused a little "shake"..
Just another thought...... YMMV
Old Sep 12, 2010 | 03:41 PM
jplinville's Avatar
jplinville
Check transmission connection at the crossmember.
Old Sep 12, 2010 | 07:03 PM
rikard's Avatar
rikard
Besides the other suggestions I would also check the rear springs, perches and shackles. It could be axle hop.
regards
rikard
Old Sep 29, 2010 | 12:51 PM
octaneforce
sorry to bring back this post, but my situation has gotten worse. the truck makes a clicking and popping noise while going slow, especially thru turns. it seems to be coming from the rear end. the thumping/shuttering noise is also still present. i JUST had this rear end rebuilt. how could i check my springs and and shackles in the rear?
Old Sep 29, 2010 | 01:04 PM
White 97 xlt
Have you dropped the driveshaft and checked the U-joints?
Old Sep 29, 2010 | 01:07 PM
chillmiller's Avatar
chillmiller
let the poor woman out of your toolbox man
Old Sep 29, 2010 | 03:22 PM
deeznuts822's Avatar
deeznuts822
Make sure that the clips are still intact on the ujoints,if they are go see the rearend rebuilder that did it. When i purchased my truck the front wheel bearings were loose and it made a horrible thump
Old Sep 29, 2010 | 04:49 PM
jpcnorthwood's Avatar
jpcnorthwood
Is it coming from you tranny? The torque converter shakes and shutters when it goes out. It is an odd feeling.
Old Sep 29, 2010 | 07:56 PM
octaneforce
the truck has a manual transmission. do manuals have torque converters? anyway. i am gonna crawl under and check out the u joints tomorow, even tho i just put those in a few weeks ago. i brought it to the mechanic who rebuilt the rear and he said the noise was coming from my leaf spring clamps shifting. i took those off and it still makes the identical noise. if i cant find anything im gonna bring it back again.
Old Sep 29, 2010 | 09:14 PM
jpcnorthwood
Oops, didn't see it was a manual.
Mcfarlane11
Feb 11, 2014 07:10 PM
Splatts
35
Jul 9, 2012 12:56 PM
BillyBob69
Oct 23, 2008 08:16 AM
nauticalrich
1983 - 2012 Ranger & B-Series
Dec 28, 2006 04:40 PM
pdlstl
Nov 11, 2002 08:24 AM
